Roval 2020/2021 Road Wheelsets
Forum rules
macwatt
by macwatt
Hi
This is an email I received from Roval on the selection of tyre width for Alpinist or CLX Wheels
Our Turbo Cotton in a 700x26 has been shown to be the fastest tire combination across a variety of surfaces. Additionally, the use of latex tubes can also decrease rolling resistance. You can use up to a 28mm tire with the Rapide CLX and benefit aerodynamically, and this may offer better ride quality on rougher roads, but terrain, ride surface and a number of other factors can greatly effect "fastest tire", which is why you see the pro peloton use different tire choices in TTs, road races, and classics.
FlatlandClimber
by FlatlandClimber
mhw23 wrote:
Sun Jun 27, 2021 5:52 am
What is the optimal tire width for the Alpinist CLX wheels?
The Alpinist are hardly aero at all, so it just depends on what you want.
Narrower on the front is more aero, and wider on the rear rolls faster at hardly any rolling resistance penalty.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
LBoogie28
by LBoogie28
Has anyone run a pair of conti 5k in size 28 on the rapides? Moving over from a pair of clx 50's, where I have primarily run turbo cottons (in 26). Was thinking my first tires should be the same as I have always used, as a way to compare the wheelsets, but that front width in the rapides has me thinking bigger tire.
mhw23
by mhw23
Trying to maximize speed so that’s why I’m asking. Turbo Cottons have a bad rep for low puncture resistance.
FlatlandClimber
by FlatlandClimber
However they are about the fastest road tires there are (baring TT tires). I run them on my Aero bike and TT Bike.
The best alround tire for me is GP5000C.
I would run 28s on the Alpinist and even consider 30s on the rear.
I run 28c front and 30c rear on my Bontrager RSL 37 for mountain races. Great comfort, fast enough, and traction. The wider tires also make it easier to ride up very steep climbs standing, where smaller tires might start slipping when road isn't perfect.
mhw23
by mhw23
FlatlandClimber wrote:However they are about the fastest road tires there are (baring TT tires). I run them on my Aero bike and TT Bike.
Got it. I’m running the GP5000 in 28mm on the Alpinist CLX right now. Tan sidewall tires are tempting me and I wish they were available in 28mm for the GP5000. I run the same tires on my Roubaix with the CL50 wheelset and they are working out well.
BianchiDave
by BianchiDave
LBoogie28 wrote:
Sun Jun 27, 2021 2:25 pm
I'm running GP5000s 28s front and rear. Tbh I think the front is so wide you need a 28 to prevent rim damage. I fitted a 25 initially and there was way too much rim poking out for my liking - so much so a rapid deflation could have caused the rim to to contact the road. Whilst still considerably narrower than the rim,the 28 looks more reassuring!
macwatt
by macwatt
I fitted 28mm for the same reason with the outer rim being so wide I cannot see why running 28's would be an Aero disadvantage compared to running a narrower tyre.
pmprego
by pmprego
macwatt wrote:
Mon Jun 28, 2021 8:22 am
A bigger frontal area will never be the same as a smaller frontal area. You might say you get other benefits but that's how it is. It is also why you see Zipp go for a "thinner" 454 or dt swiss also with their aero wheels. They are going for pure, frontal speed. Roval kind of went for the all-rounder type of wheel that is also very deep for all-rounder.
Id still prefer them to go for something like 40/45 deep and tubeless but that's me.
bruno2000
by bruno2000
I have a Vittoria Corsa Control 28 on my Rapide CLX front wheel and the rim is still poking out a bit. How is that?
On the rear I've mounted a Vittoria Corsa Control 25mm which matches the Rapide CLX rear rim nicely. (I had 2 Corsa Control tyres as good as new in my garage so decided to only buy 1 in 28mm)
On my Alpinist CLX wheels I had 2 Turbo Cottons 26mm but I punctured the rear and replaced it by a Schwalbe Pro One TT 25mm which I had left. Although the Schwale only being 25mm it pumps up to the same size as the Turbo Cotton 26mm front.
IMO 25mm is the best match for the Alpinist.
mhw23
by mhw23
bruno2000 wrote:I have a Vittoria Corsa Control 28 on my Rapide CLX front wheel and the rim is still poking out a bit. How is that?
Do you run both wheelsets on the same bike? If you had to get only one which would you prefer?
jadedaid
by jadedaid
Anyone else find that the hubs don't like wet weather much? I had 2 rides in the wet, and got the fading hub sound. Had my wheels regreased, and everything was fine until the next 2 rides in the wet. Now the fading hub sound is back.
Wondering whether it's because of the 'old' ratchet that will need replacing or if it's just a feature of these hubs that they don't hold up to bad weather very well?
bruno2000
by bruno2000
mhw23 wrote:
Sun Jul 04, 2021 3:00 pm
If I had to pick one I would pick the Alpinist for my riding.
Offcourse the Rapide will be more aero and they do give you a feeling of speed (great sound) but my rides max avergare speed is allways around 30km/h. (I actually do not need all that fancy stuff but I just like nice things)
So I do not believe the more aero Rapide gives me much 'speed-wise'. They do feel more comfortable than the Alpinist. Probably due to the large tires and the larger rim width.
The Alpinist are much snappier and feel stiffer, probably due to their lower weight.
And although I live is the most (stupid) flat part of Belgium (oh boy I wished I lived in the Alps like mys sister does), I do prefer my bikes to be as light as possible.
(I have a Cannondale Super Six Evo with Shimano Ultegra di2 (Rotor Aldhu+ crank, KMC X11SL chain and Dura-Ace cassette), Vision Metron 6D handelbar, stock sp and SLR Kit Carbonio saddle. With Alpinist CLX wheels (Schwalbe Pro One TT 25mm+tubolito) the bike weights 6.89kg, with Rapide CLX (Vittoria Corsa Control 28-25+tubolito) the bike is 7.15kg.
FlatlandClimber
by FlatlandClimber
I kinda doubt anybody is reliably able to feel a 150g difference, especially when riding on the flat.
Not saying it impossible, just having a hunch this might be a little on the Placebo Side of things :noidea:
but maybe it's just me who doesn't believe in these weight differences making a noticeable difference, especially on the flat.
In a 75kg system for example, that would be 0.2% of the system weight saved...
Even if you bro science things like "rotational weight is at least double" that would still be like saying "my bike feels significantly snappier depending on if I have 600 or 300ml of water in my bottle.
Nevertheless, the Alpinist are likely Great wheels...
The difference in stiffness maybe a thing. I don't know how the Alpinsit feel.
However, regarding "lighter wheels accelerate better": that's only from
Very slow speeds. In an all out sprint at higher speeds (even 30kph to 40kph), the reduced Aero-drag will far outweigh the weight advantage.
All that would lead me to the conclusion of taking the amazing Rapide. They are amazingly fast and stable!
ryanw
by ryanw
Deeper wheels / shorter spokes = stiffer at point of load.
Aplinists will not be stiffer at all unless spoke tension has been cranked right up.
IG: RhinosWorkshop
