Gshb’s Litespeed Watia
gshb
by gshb
Waited four months for this 2022 Watia from Litespeed. Rides so nice, well worth the wait. Inspired by @RyanH to go titanium and the Watia will serve as my do it all.
Weight as per photo above:
8.73kg
Looking to replace the stock seatpost clamp and axles, just not sure with what.
R8000 pedals measured 247g, under the claimed 255g:
Will eventually replace GK SK with Terra Speeds 650bx40mm:
gshb
by gshb
Bonus pic:
This is with M9100 vs above YBN SLA1210-TIG chain.
tonytourist
by tonytourist
Looks nice with the 650B setup!
dtwolfen
by dtwolfen
What's the tire clearance with the 650b? How much larger than 40mm will fit? Thank you
Sent from my SM-G973U using Tapatalk
gshb
by gshb
So the Panaracer GK SK 48mm on HED Emporia GA Performance 25mm ID wheels measures just over 50mm F/R 32/36PSI:
Clearance with Enve G fork well over 1cm at sides, 2.5cm vertical clearance:
Rear clearance with chainstay 6mm and Litespeed's official claim of 53mm for 650b seems spot on:
gshb
by gshb
Wanted to update this with road wheels and tires and a few other updates. Weights updated in first post.
Decided to get an Sworks stem 12deg, which saved 14g.
Also liked that the cheaper MT800 rotors are basically same weight as MT900.
