AX lightness 2014
Stunning bike.
A build list might help a little.
De Rosa Idol - 6.63kg viewtopic.php?f=10&t=153136&p=1572170#p1572170
Frame ax lightness vial evo 2014
Fork Thm clavicular
Stem 3t stealth 100mm 6 degree
Sram etap
Ee brakes
Ax lightness ergo 4200 handlebar
Quarq dzero power meter with red crank arm
Reynold SLG 46mm wheels with gp4000iis tyre
KMC SL chain
Dura ace pedal
Dura ace 11-30 cassette
Berk lupina saddle
Guee dual SL bartape
Bontrager xxx bottle cage
Planet x carbon-titanium skewer
Fsa k-force seat post
Im very new with all this, pardon me if i miss out some essential stuff
What do u guys think about the bartape... in 2 mind abt it...
Looking for a set of aluminium clincher. Mavis sys slr is 1300g
Thanks
Des
Fork Thm clavicular
Sram etap
Ee brakes
KMC SL chain
Dura ace pedal
Berk lupina saddle
Thanks
Des
Although I'm an all-black bartape guy, I kinda like this. It suits the bike nicely.
Not a ton of room on this build to drop weight unless you're willing to drop some serious coin. The first place I'd start, other than the wheels as you mentioned, would be the seatpost. You could easily drop 50+ grams right there.
I purchased an Aliexpress Carbon post for about $30 that comes in at around 155 grams after I hacked off about 130mm. But you can find much lighter.
Next, although DA pedals are great, they are comparitively heavy. I went with Speedplay Chromoly and swapped the spindles for J&L titanium spindles. 160 grams for the pair. That would save you about 90 grams right there.
You could probably drop about 20 to 30 grams on the stem with a Kaloy Uno. 110mm is about 100 grams with titanium bolts.
Same suggestions:
-stem—>Kalloy or Extralight
-seat post—>AXLightness or aliexpress
-wheels—> many choices here simply dependent on budget
-pedals—> Time 15 pedals are the lightest and yet very robust with large engagement and platform area
Also, depending on what fork expander and cap you have, you might be able to save some grams there. Same for the seatpost collar.
The Herd
viewtopic.php?f=10&t=149524
Very tidy build.
My burgeoning stable
Serotta Colorado II - Heavy
Klein Quantum Pro - 7.3kg
Gios Carbon V107 - Ongoing
Thanks for the advice
The bike actually come ax lightness seatpost with a 0 degree setback, but my bike fitter suggest a 25mm setback
I will likely take your advice on the stem!
How do you change the time axle on a dura ace pedal please
Thinking to change to bora 35 clincher
Des
Des
