63cm CAAD10 build
Definitely going to consider some carbon wheels for it too
Decided on a hylix zero seatpost with Ti hardware as the price/gram ratio is so good. Second only to the kalloy uno stem..
Still thinking about the bars. I’m inclined to stick with alloy. Suggestions?
Loosely decided to go with all Ultegra 6800, but a BB30 native crank. Short listed the Rotor 3D.
I still have the old FSA SL-K 44cm bars I might reuse for now.
The rebuild is in full swing, I sold my Propel to focus on this.
I should have the custom decals (much more minimal than the standard scheme) sorted by next week and then I’ll be sending the frame and fork off for professional paint the week after.. it’s going to be a fluoro colour that’s all I’m saying.
I’ve pieced together a full Ultegra 6800 groupset to use on the bike.
It will be heavier than before when it had the Red 10 speed but I’m much happier on Shimano.
Hopefully there will be enough left in the bank for some carbon wheels once the build is complete. If not my existing Kinlin/Aivee wheelset (1460g) is a lovely riding wheelset for the meantime.
Frame is at the painters for refinishing .. no decals, all paint.
A custom mixed red with gold lettering and brushed aluminium rear triangle is the order.
https://www.instagram.com/p/Bxw6Nzyn4BE ... ojgzfcv8kf
https://www.instagram.com/p/BxxKmrgHN6d ... urohakt9wu
Ultegra 6800 group .. kmc chain, FSA bb30-24 reducers, Aican bungaru cables ready to go .. just waiting for KCNC cb9 brakes to arrive. https://www.instagram.com/p/ByMYKCyn3Ok ... 9a3i2d7hqf
Fabric Tri Ti saddle, Tacx Diva cages, K-Edge Garmin Mount with Ti bolts and supacaz tape. I have black and white saddles so will see what looks best when the frame is back from the painter.
https://www.instagram.com/p/ByMJ39IH4MC ... kluu3qbnss
Everything is getting individually weighed as I build the frame up.
No hanging scales at the moment so no final weight, but here's some pictures. I'm planning on changing some of the finishing kit later on so I didn't worry too much about weighing everything. I'll add in the rest of the weights and some proper pics later but here's the current build list.
Frame - 2013 Cannondale CAAD10 63cm
Fork - 3T Funda Pro
Hanger - Cannondale
Headset - FSA Orbit with carbon top cap
Seatpost clamp - Cannondale with Ti bolt
Seatpost - Hylix 27.2
Seat - Fabric Tri Elite with Ti rails
Stem - Kalloy Uno with Ti bolts
Bar - FSA Wing Pro 42cm - 270g
Bartape - Supacaz Super Sticky Kush
Bottle cages and hardware - alloy bolts
Outer Cables - Aican Bungaru
Inner Cables - BBB PTFE coated
Brakes - KCNC CB9 - 213g pair (actual)
Front derailleur - Ultegra 6800 braze-on
Rear derailleur - Ultegra 6800 short cage
Crankset - Ultegra 6800 52/36, 175mm
Bottom Bracket - KCNC BB30-24mm
Chain - KMC X11-SL
Shifters - Ultegra 6800
Cassette - Ultegra R8000 11-28 - 238g
Wheels:
Hubs - Aivee SR2
Spokes - Sapim Super
Rims - Kinlin XR22
Inntertubes - Vittoria Super Lite 18-23
Tires - Michelin Power Competition 700x25c
Pedals - Garmin Vector (upgraded to Vector 2 pods)
Garmin mount - K-Edge with Ti bolts - 31g
https://photos.app.goo.gl/sGTrh66W7wKgeZaJ9 for pics
Fork - 3T Funda Pro
Hanger - Cannondale
Chain - KMC X11-SL
Wheels:
Hubs - Aivee SR2
Rims - Kinlin XR22
I finally found some proper image hosting.
I got the frame back from the painter now it’s all in solid red.
Built up .. put some Cannondale Escape Hanger carbon bars I got for a steal and supacaz bar tape.
Also got some carbon cages and had them custom painted.
Next up some carbon wheels .. probably upgrade the seatpost and stem at some point also.
Current weight is 7.5kg even.
The linked images don't load. Why not attach photos directly to posts?
[/quote] I’m glad you asked .. for some reason I couldn’t attach images directly to posts from my devices for a while but now it works again!
As above pretty happy with the bike now .. may change the finishing kit up a bit, and add some carbon wheels but overall it’s time to ride the hell out of it.
Finally some decent pictures with some Bontrager Aeolus 5’s :
