Monstercross-esque Chisel
Upcountry
by Upcountry
Not really... People mix and match boost spacing rear ends and cranksets all the time. By using a 0mm offset ring, I'm essentially doing that. Perhaps the largest cog is a bit noisier due to the chain articulation, but its not significant.
CAAD8FRED
by CAAD8FRED
Upcountry wrote:
Thu Dec 21, 2023 7:19 pm
Do I need a wider spindle to run the 0 offset ring? If so where can I find a wide spindle arm set? I've been looking but it appears to only be on transmission. Thank you
andrewbn42
by andrewbn42
No, you can use a zero offset chainring with a normal crank.
If you want a 55mm crank, you can look for a sram super boost crank, or they make 55mm quarq crankarms. Both a wide crank and zero offset can get you a big chainring, but the chainline will be fairly poor for the big cogs in the back.
jfranci3
by jfranci3
CAAD8FRED wrote:
Fri Dec 01, 2023 2:18 am
Was thinking of getting a chisel and putting a 40 mm travel fork on it with drop bars and trying to get it close to a monster cross 29er.
Two issues I would like advice on:
Max tooth chainring I can run on a chisel and other similar hardtails that may be able to take a bigger ring?
Would reducing the travel from the stock fork affect the headtube strength of the bike?
The only things I'd add to think about- water bottle capacity, wheelbase, and head angle. If you're going to be doing long rides, I'd size up for better water bottle space. The bike is going to be quite a bit longer than a gravel bike. With the shorter fork, the head angle is going to change pretty radically - find a website and figure out the change at sag.
I don't understand the shorter fork thing. You're going to get better fork options out of a proper fork. A rigid MTB fork is like 800-900gr, a gravel suspension fork is like $700@ 1300gr(?), and a cheap/good Reba takeoff is $200 @ 1600gr.
kervelo
by kervelo
jfranci3 wrote:
Sat Dec 23, 2023 3:31 pm
Another great option for a monstercross bike would be the previous generation Rockshox Sid SL Ultimate. With 1320 grams it is very light and it was quite recently available for around 450€. You can also always lock the suspension fork if the conditions require that.
Upcountry
by Upcountry
In my instance, the shorter fork thing is two fold: to increase the head tube angle a bit, to get it more inline with a gravel bike versus a mtb. And secondly and probably more importantly is simply to decrease the stack. I simply couldn't get my bars low enough in relation to my saddle position to get close to a similar feel as my other drop bar bikes. And this is in conjuction with a pretty extreme stem angle. I do fully understand the argument against a "gravel suspension" fork for this use case though in terms of weight and price.
wanderlustcycling
by wanderlustcycling
TwincamRob wrote:
Fri Dec 01, 2023 5:30 pm
40t
amazing set up!
which parts did you use?
-sram axs xplr rear derailleur?
-axs xplr cassette? which range?
-original chisel crankarms?
-which bottom bracket?
is the xplr rear derailleur compatible with eagle axs mtb shifter?
Upcountry
by Upcountry
Scroll back a page and read....
Knightyboy27
by Knightyboy27
Slightly off topic but is the latest Chisel UDH? Can't find any info that it is, but looks kinda similar shape. Looking for a similar aluminium hardtail that is UDH if not.
Upcountry
by Upcountry
Knightyboy27 wrote:
Fri Dec 29, 2023 10:27 pm
The Chisel and Epic HT are not UDH... The Epic Evo is, and I'd imagine any new MTB's from Specialized will be UDH.
