I have an old Cannondale 3.0 MTB frame from 1990 that I would like to set up with a SRAM 1x crankset.
The frame is actually very close to a road configuration: 68 mm BSA BB, 130 rear drop. Currently it has a 3x crankset, 48/36/24 and CL is 45 mm on the middle ring and 50 mm on the outer ring.
I think I could use a SRAM Force 1 crankset with a decent 8-bolt direct mount chainring. Chainstays are 115 mm wide and the cranks require 2 x 60 mm space according to SRAM specs.
Or do I neet to use an MTB crank, which seems much more expensive (XX1, 8-bolt direct mount)? And for some strange reason it is stated that it would only work with a Quarq powermeter??
1x SRAM road crankset for old Cannondale 3.0 MTB frame
I can't answer your question directly but can confirm a 1x Saint BB crank and BB bolt straight in with no issues.
https://flic.kr/p/FWjk7r
Thank you and very nice revival of that bike. Yeah, Saint has a larger q-factor and chain line. I am looking at a q-factor of approx. 145 mm versus 175 for the Saint. So on each side, the crank would be roughly 15 mm closer to the chainstay. But I also note your frame has the rectangular chainstays that might not be as wide. Thanks!
- 2019 Specialized Tarmac SW SL6 Red AXS Zipp 303
2019 Cervelo P3 II Red AXS 1x Zipp 808
2017 Cannondale Slate Force CX1 stock
2012 Specialized Tarmac SL2
2011 Cervelo P3 - under conversion to single speed/fixie
2009 Cannondale CAAD9 Ultegra
BB shell and chainline will work. Chainring clearance should be ok too given it's 36 in middle and 46 big. The one thing I'd be unsure about is the crankarms hitting the chainstays with such a narrow q factor. My experience is that that era usually clear but only just. It's really hard to know without just installing some cranks and trying it. I'd say go for it.
Yeah, SRAM states that the road cranks have 120 mm (2x 60 mm) space inbetween. The chainstays are 115 mm wide in total, according my measurements. So it will be very tight, but could work! Sadly, I have not found the wider Force cranks in a cranks-only version, that would give me another 2x 2.5 mm.
Another question: I would expect that the road cranks and the direct mount chainring have a front chainline between 43 and 45 mm.
Wolftooth states 45 mm (I understand with 6 mm offset).
Gargaruk could result in 2 mm less it seems the chainring in my preferred size (40t) has an 8 mm offset.
Which is preferable?
Actually, let's say I cannot mount the road crank because of the chainstays and would have to revert to a MTB crank. Would the expected 47-49 mm offset actually work with an 130 mm rear hub? It looks like the feasibility of my project depends on whether I can mount a road crank.
