Inside watts vs outside watts? and could something be interferring with ANT+ connection?
Catagory6
by Catagory6
my goodness, indoor watts on the Saris H2 feel FAR easier than outside watts on the pavement.
i've compared the Assioma pedals with the trainer, and they match up just about perfectly.
but outside, 200w "feels" easily like 350w inside on the trainer.
is this typical?
also, i notice quite frequently that the power reading from the Assioma drops dramatically quite often.
not to mention the constant 30-50w power fluctuation over consistent gradient, and i have my computer set to 3s average.
and there is one section of road, where no matter how hard i sprint, power numbers are always around 150ish watts.
could something be interfering with the ANT+ connection?
MrCurrieinahurry
by MrCurrieinahurry
What program and hardware are you using?
Basso Diamante rim Campagnolo EPS 12 Bora WTO 60's
Catagory6
by Catagory6
outside, assioma single with garmin fenix 5 ANT+
trainer is saris H2 with wahoo systm via bluetooth. simultaneously recording with the garmin ANT+
MrCurrieinahurry
by MrCurrieinahurry
On pc? Laptop? Etc
Catagory6
by Catagory6
MrCurrieinahurry wrote:
Mon Jan 22, 2024 10:05 pm
On pc? Laptop? Etc
nah, i don't take my desktop computer out on the road...
ahahaha, iMac
spdntrxi
by spdntrxi
since Kickr v1 to my current Tacx Neo... outside watts always easier.. 200w outside if like 230 inside.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
EdWiser
by EdWiser
If it’s Zwift the default 50 % of reality seti g is the issue. While you can get the wattage. The 50% reality does affect your legs like 100% reality.
https://youtu.be/L6xOmDxyxtU?si=7NjnfmflTD8nGFCW
MrCurrieinahurry
by MrCurrieinahurry
He did say he's using wahoo system... Reason I ask was if you were using Zwift you could have dropped the file into zwiftiziler 2.0 and seen about the dropout issues you were having.
TobinHatesYou
by TobinHatesYou
Use the H2 with SYSTM while recording the same ride with your Assiomas+Fenix. Upload both FIT files to https://compare-the-watts.com/
