Aero Handlebars in gravel
damond
by damond
I know this might be a sensitive subject but which aero handlebars are available with some flare that can be used on a gravel bike?
As for the moment i am only aware of:
- Enve Aero
- 3T AEROGHIAIA INTEGRALE
- Deda SUPERZERO GRAVEL
Integrated barstem system can also be an option!
thanks
voicycle
by voicycle
Enve SES AR are a bit more gravelly than the Aero but still an aero handlebar. Main aero compromise is with most setups you have to wrap the tops to keep the hoses in place (channels rather than internal).
The new Enve SES AR cockpit goes one-piece and eliminates that need.
FSA K-Wing AGX is aero-ish
Prime Orra Aero is just the flared version of a well-regarded budget road option.
I think there a fair number of OEM one-piece setups with flare, though I don't know how many are available aftermarket:
Black Inc / Factor
BMC Kaius barstem
Ridley Kanzo Fast might have one?
Ribble do one for their bikes and I bet a lot of other 2nd tier manufacturers do similar.
spdntrxi
by spdntrxi
I use the SES AR with a Enve aero stem.. Pretty happy with the combo. I have a 40cm now, but switching to 38cm.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
RDY
by RDY
I use the Lambda Cross-Wing Aero. Super narrow on the hoods, quite a bit of flare, and short drop. Size 42 (at drops) and 35 at hoods - it's the one with the larger clamp area, so I can add some clip-ons if needs be.
fizzaz
by fizzaz
I have strong opinions on this topic:
AERO HANDLEBARS IN GRAVEL ARE POINTLESS
When you go to reg at your next gravel race, they will inevitably hand you a number plate to put on your handlebars - all bar aerodynamics are now negated and to lesser extent frame aerodynamics. Go with the best shape that suits your morphology for a fast body position and then pick the lightest you are willing to pay for. Voila, fast gravel bar.
spdntrxi
by spdntrxi
^ who said anything about "racing" ...
you had to know that was coming :wink:
2023 Pivot E-Vault
krzn
by krzn
fizzaz wrote:
Wed Feb 07, 2024 4:10 pm
Some of us use their gravel bike as road bike by simply changing the wheels, et voila, you "need" all the aero gains you can get.
But when it comes to strong opinions ... flared handlebars are pointless :noidea:
req110
by req110
Who says you can't wrap the race number around your head tube? You don't have to have on the handlebars like some parachute.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
tiberiade
by tiberiade
req110 wrote:
Wed Feb 07, 2024 9:28 pm
I tried doing that and was asked not to during Traka.
req110
by req110
I am sad to hear that. At least if you can mount it on the seatpost. :(
spdntrxi
by spdntrxi
tiberiade wrote:
Wed Feb 07, 2024 9:38 pm
I feel like the number is for the photogs and you to be able to find your pics so they can be sold after the event. I'm not in the lead pack so I'll wrap that number around the headtube. Never been hassled.
2023 Pivot E-Vault
fizzaz
by fizzaz
Races almost always ask that you do not wrap it, especially at the pointy end or the race. Also, doing so scratches your paint like a mf'er. Ask how I know in both instances.
RDY
by RDY
I've never heard of someone being asked to use it as a sail on the bars if they're using a number holder on the seatpost.
1swiftvelo
by 1swiftvelo
PRO is coming out with a aero gravel bar. Should be available around May hopefully.
njleach
by njleach
I'm running the 3T Aeroghiaia on my ADHX45. 400mm at the hoods, about 475mm in the drops - it's very comfortable
