Roval Terra CLX vs Reserve G25
justonwo
by justonwo
I'm considering both of these wheels for a frame-up build. I like the Roval Terra CLX wheel specs and have in general liked my Roval wheels. I like that they are very light and have DT180 hubs. I have heard from at least one mechanic that they aren't as strong/durable as the G25.
I have no experience with Reserve wheels. They seem great but are 180 grams heavier.
I'd like to keep the bike as light as possible. I don't need to go full road bike weight weenie on it, but to me the Rovals seem like the winner here. I should mention, I only weigh 150 lbs, so I am not going to put maximum load on these wheels.
Anyone care to help/comment?
2020 F12 AXS Red (Zipp 353)
2021 S-Works Aethos Di2 9200 (Alpinist CLX II)
2006 Cervelo Soloist
2021 S-Works Epic
2024 Topstone Lab71 (Force/XX1, Terra CLX II)
Retired: 2014 and 2020 S-Works Roubaix
2020 Canyon Ultimate
2018 S-Works Camber
pushpush
by pushpush
Both are good wheels.
Does weight or durability score more points for you? Choose one.
Provided you are purchasing them new, both should come with great warranties so durability may not be the most important consideration.
justonwo
by justonwo
When you say choose weight vs durability are you speaking from experience? The Terra has lower durability than the G25? Or you're making an assumption that the lower weight reduces the durability?
2021 S-Works Epic
2018 S-Works Camber
parleez1
by parleez1
I have the Roval Terra CLX II wheels on my Enve Mog and so far I love them. I weigh 145lbs, so not to worried about durability and as mentioned above Roval has a very good warranty. Can't speak to the Reerve wheels, good luck, probably can't go wrong with either choice, buy the ones that speak to you.
TLN
by TLN
Used to have Reserve 40|44 with DT-350, swapped with Terra CLX. Lighter and faster wheeset. Probably due to the hubs: DT-350 vs DT-180.
Terra CLX is sub-1300gm, with II version being even lighter then that.
His: Orbea Orca OMX
