2024 Shimano RX825 2x12 GRX Di2
ooo
by ooo
ooo wrote:
Tue Apr 16, 2024 5:48 pm
Image Image
IFDRX825F FD-RX825 (di2 derailleur price listed with mechanical derailleur image)
IRDRX825A RD-RX825 (di2 derailleur price listed with mechanical derailleur image)
shifter is not price listed, there is some shifter in fcc listing (ST-RX825 or something else),
no derailleur in fcc listings (either it uses equal electronics to other wireless derailleurs or it is not wireless or it will be listed later)
ooo
by ooo
bike with 12-speed grx di2 shop listing:
fietsenmagazijn.nl/orbea-terra-m20iteam-2024-gravelbike-carbon-myo-l/
puls-schlag.com/Orbea_TERRA_M20iTEAM_M_Cosmic_Carbon_View-Metallic_Olive_Green_(Gloss).html
2rcbw.com/terra-m20iteam/
RDY
by RDY
Assuming it works with an 11-34 or 11-36, I'll be swapping out the Ultegra 12s RD on my road bike. The design should result in less chain suck and slap even when the clutch isn't in the engaged position.
ooo
by ooo
Yes, RD-RX825 will do 11-34/11-36
Orbea 2x12 grx di2 bikes spec'd with RD-RX825 and 11-34T.
I haven't seen any 1x12 di2 grx parts or bikes options so far.
satanas
by satanas
No levers? Maybe they're still wired and use the old 11 speed Di2 levers with a wiring adapter and firmware update as with DA & U rim brake???
zmjones
by zmjones
satanas wrote:
Thu Dec 28, 2023 12:48 am
can't imagine that but wouldn't that be a treat. i do wonder if they've really thought about the incremental income they'd get from making partial upgrades possible. i think they ought to at least try it at some point.
ooo
by ooo
ST-RX825 grx levers are listed in second post in orbea 2024 gravel bikes specs (last line in screenshot).
levers not listed on spare parts price listing right now, but they should be available later
RDY
by RDY
I'd imagine RX825 brifters will be unchanged except firmware. They were already servo wave, and I never heard of someone not liking their shape and size. But being able to flash the old ones? This is Shimano ...
robertbb
by robertbb
Surely they'd have to change to accomodate the coin cell battery/batteries.
Plus they'll likely bring the shifters in to meet the design language of the road stuff, with the "shroud" over the lever.
I also wonder whether they'll introduce two levels of Di2 GRX. One, for example, similar to 105 with no servowave, no sattelite connectivity nor hood buttons (but with dual coin cells) and one similar to Ultegra/DA with servo, sattelites, and a single battery. This is unlikely I feel.
satanas
by satanas
It was alleged somewhere (I can't recall just where) that Di2 only made up a small fraction of GRX sales, so the chances of multiple options/levels probably aren't high.
ooo
by ooo
Shift-Brake levers, deraileurs capacity
SHIMANO brake-set GRX BR-RX820/ST-RX825 front BR/left ST FLAT MOUNT polymer+cooler SMBH90/1000m
4550170640071
IRX8251DLF6SC100A
SHIMANO brake-set GRX BR-RX820/ST-RX825 rear BR/right ST FLAT MOUNT polymer+cooler SMBH90/1700m
4550170640101
IRX8251DRRDSC170A
SHIMANO derailleur GRX-Di2 FD-RX825 for 2x12 welder Down Swing/61-66 for 48T C.L: 47 mm box
4550170310646
IFDRX825F
SHIMANO derailleur GRX RD-RX825 12 speed gravel max 36T min 11T capacity 41T box
4550170310899
IRDRX825A
robertbb
by robertbb
no specific 1x rear derailleur?
ooo
by ooo
distributor channel: no 1x rear derailleur yet (see picture below)
oem channel: I am waiting for info
ST-RX825-L
ISTRX825LA
4550170639785
ST-RX825-R
ISTRX825RA
4550170639839
expected stock: 2024-06-01
thumper88
by thumper88
ooo wrote:
Sat Jan 13, 2024 5:26 pm
ST-RX825-L
ISTRX825LA
4550170639785
ST-RX825-R
ISTRX825RA
4550170639839
I realize you posted this mid-january but... this leaked stock list is obviously from Europe. So, point of clarification on that 2024-06-01 expected stock date, is that maybe an outdated official guesstimate in European style with the day before the month (making it January 6), or are you saying that you've already transposed the date to US style and the expected stock date is June 1?
raisinberry777
by raisinberry777
Shimano nearly always does releases on the first day of the month, so June 1 would be more likely.
