Time ADHX 45 - A proper gravel ADHX
njleach
by njleach
Looks great Andy - what tires are you running on there? Rene Herse?
I'm still getting my fit dialled as well, but love the build quality and ride feel so far!
Andy340
by Andy340
I have Rene Herse 32mm on right now as I want to compare ride to my currently most used bike so using same tires for now. May go up to 35s for road (rims are 25 internal) and have a set of 650b with 47mm tires for chunky gravel type rides.
This is also my first electric shift bike so a bit of a learning curve setting trim on front derailleur etc when I swapped crank but so far so good!
It is a really well finished frame - surprised these don't get much attention compared to the more prevalent brands.
UltraMaraFun
by UltraMaraFun
Can anyone give me an idea of the standover heights for a Medium and Large, as I am on the fence as to which size to go for due to my short legs (741mm saddle height) / long torso (approx 183cm tall). TIA.
Bikes:
2024 Giant Revolt Adv Pro - AXS Eagle XX1 / GRX820
2020 SystemSIX Hi-Mod - Dura-Ace Di2 12 Speed
2021 Giant TCR ADV Pro Disc - Ultegra Di2 12 Speed
2020 Giant Revolt ADV 2 **For Sale**
2019 Genesis Team Zero Disc - SOLD Oct 2020
stalkersk
by stalkersk
You can use https://www.bikegeocalc.com/ to draw both frames and it will output stand over height in extra.
UltraMaraFun
by UltraMaraFun
stalkersk wrote:
Thu Mar 21, 2024 11:09 am
Great, thanks, I have used bikegeocalc before and had no idea the "Extra" button gave the calculated standover (as well as other things). Looks like the Large is the better fit/closest match to my current gravel bike, so thanks stalkersk, although the calculated geocalc figure for my current bike is about 20mm less than it actually is!
Bikes:
tiberiade
by tiberiade
UltraMaraFun wrote:
Mon Mar 18, 2024 3:35 pm
I run the same saddle height and I'm 181cm. My frame size is M, with 100m stem to the bottom. I would use a slanted or longer stem for a more aero position. The L's head tube would be too long for my liking. You may enjoy an M with 120mm stem?
