Cervelo Aspero-5 Integrated cockpit options
I dont have an aspero but an r5cx which I think is the same bar/stem, ended up putting a enve in route stem and compact bar. It was a bit of work to get it fitted but personally think it looks a lot better then the stock setup and a bit lighter. https://dgtzuqphqg23d.cloudfront.net/ZY ... 8x1536.jpg
Do you have closer pictures?simoncx wrote: ↑Fri Jan 26, 2024 4:07 pmI dont have an aspero but an r5cx which I think is the same bar/stem, ended up putting a enve in route stem and compact bar. It was a bit of work to get it fitted but personally think it looks a lot better then the stock setup and a bit lighter. https://dgtzuqphqg23d.cloudfront.net/ZY ... 8x1536.jpg
I have the same issue and can't combine the enve stem with my Aspero 5. Do you have any tips how i can fix this problem. Have dou drilled the holes bigger in the stem to fit the head set?simoncx wrote: ↑Fri Jan 26, 2024 4:07 pmI dont have an aspero but an r5cx which I think is the same bar/stem, ended up putting a enve in route stem and compact bar. It was a bit of work to get it fitted but personally think it looks a lot better then the stock setup and a bit lighter. https://dgtzuqphqg23d.cloudfront.net/ZY ... 8x1536.jpg
Thank you
