Narrow/wide in Campy BCD
Does anyone know if there are any manufacturers of narrow/wide chainrings with Campagnolo specific bolt patterns? I have a Campy crank I'd like to use for a CX build, but so far I haven't been able to find any narrow/wide rings for the Campy 110 BCD. I've been told you can file the 5th bolt hole to fit the different BCD, but that sounds a bit janky to me.
I was unaware of the rotor option, I was unable to find anything to suit the 135mm campag bcd. It's hard enough getting hold of a five bolt ring.
I did buy a black race face one in 130 and was planning on enlarging the outer edge of each bolt hole, using another campag ring as a template but haven't had time yet. Another WW member did that and it seems ok.
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
-- Frank Zappa
Well since I'm trying to use the 110 BCD, theoretically I'd only have to modify one of the bolt holes. Maybe it's time to finally get a dremel.
ITTY: It's super easy. Should take you about 35 seconds
You can do it with a simple round file as well, but that will take a bit longer.
