Paint removal
Hi,not sure if this has been covered before,I want to remove the painted finish off a pair of carbon forks,whats the best/easiest method to do it?Can you use chemicals or is it elbow grease only?
Ti or dye!
I think sanding them down with some fine sandpaper by hand would be best. I have removed and repainted a few carbon parts and it is very easy to do using 600-1000 grid sandpaper. Maybe there are chemicals specially for removing paint from carbon, but don't use standard paintstripper as it will damage the carbon!
Thanks for the quick reply guys.
Ti or dye!
