New Sapim Super spoke
morrisond
by morrisond
Should make strong under 1000 gram clinchers relatively easy...
From Tunes email
A shining example is the brand new, on the initiative of TUNE developed SAPIM Superspoke: Their impressive data are already a good entrance-card - and so we are presenting the lightest stainless steel spoke ever made!
The Flyer Super Spoke has been developed for extra light wheels. A new grade of stainless steel enables Sapim to reduce the diameter of the spoke, whilst increasing its strength and fatigue resistance. Effectively, the CX-Ray spoke decreases in weight by 17% and increases in strength by 120N in the middle section. So we get closer to an admission in the TUNE assortment...
Superspoke 21% more fatigue strength than CX-RAy
Superspoke 64x260 231 grams
CX-Ray 278 grams
To adapt Goethe: „All theory is grey...“ - with TUNE it is traditionally getting colorful – so let´s go to hit the trails! After Marcus Klausmann and the CENTRAL-Team have tested the capability in hard use, we welcome the new SAPIM Superspoke as a new member!
$mokeyJoe
by $mokeyJoe
Is this just a round spoke or a aero one?
*Light is beautiful*
BMC SLC01 5900g ... Litespeed Vortex 6300g ... Merida Carbon Lite 7000g ... Velocite Selene 8000g ... Argon18 E114 +/-8500g ... Trek 1500 9500g
Overweight
by Overweight
Those spokes are on the new Ax lightness wheels.
CippoForLife
by CippoForLife
Really?
AX Lightness website lists the spokes as CX Rays.
Tubes6al4v
by Tubes6al4v
That's pretty damn light. Now if only they could get a good distributor to reliably stock Sapim spokes.
jmartpr
by jmartpr
Round spokes....
$mokeyJoe
by $mokeyJoe
Thanks jmartpr. I'm just searching around the net...
Maybe a good start for a new set...just as a mag90 hub that i would like to have in hands.
ergott
by ergott
17% lighter means 17% less stiff. Keep that in mind when coming up with the specs for your wheels.
-Eric
$mokeyJoe
by $mokeyJoe
Well eric, i'll keep that in the back of my head...but all my other wheels have Dt Aerolites and even a bit less of flex wouldn't bother me. I'll combine it with high tension. ;-)
Danton
by Danton
ergott wrote:17% lighter means 17% less stiff. Keep that in mind when coming up with the specs for your wheels.
-Eric
Apparently the tensile strength is higher than a CX-Ray
morrisond
by morrisond
Correct me if I'm wrong, but the stiffness of a spoke has almost nothing to do with wheel strength, it's the fatigue strength that is most important.
How stiff can you make a spoke that is so thin anyways?
mythical
by mythical
Pillar PST X-TRA titanium aerospokes are still lighter...
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
andy2
by andy2
The stiffness of the wheel is achieved through the tension of the spokes
where wheel geometry and the actual force achieved through wheel architecture is the most important factor determening wheel stiffnes.
The fatigue strength of most spokes is already far and beyond that of most nipples and spoke threads (and rims and hubs).
The elasticity of the spoke is a much more determinant factor in the actual perfomance of the wheel (torque transfer, stiffness, sensibilty to steering input etc).
This pretty much rules out the Pillars...
Aerolites and Cx Rays excel in this regard.
Spokes break from crappy builds or from reusing old spokes.
rolobikes
Danton
by Danton
mythical wrote:Pillar PST X-TRA titanium aerospokes are still lighter...
Yes but as Andy2 says, they don't build into good wheels because of their elasticity.
