202x "New" Allez Sprint
oh not anticipating a new model this year, this is just a new thread to split up the existing megathread so there's a new one just for the current SL7-derived model.
also - really glad I had the park IR tool for fishing the brake line around the BB on this frame - that "shell inside a shell" construction is kinda neat looking but does not make for easy cable routing.
If memory serves - 2 generations so farspartacus wrote:How many generations have there been now and what are the differences?
- one that uses og Venge seatpost
- one that uses sl7 forks and seatpost (current one)
There may be one generation before those which is called the s-works allez, so kinda like the forefather of the sprint. It has a very aggressive geometry, more aggressive than the Tarmac series if i remembered correctly. The frame shape looks like normal allez at the time though just lighter and stiffer.
As this is a new topic, i thought it would be nice to have the new colorways listed
https://www.specialized.com/us/en/allez ... 520-221508
A Dane relocated to Sydney - and now back in CPH...
Very happy how the assembly turned out. Wasnt happy with all the 3D-printed spacers floating around so sticked with stocked; tidied up the cables under the old venge stem and we are good to go. Red/Rose latex slip will be changed for black one
Pretty happy with how my setups turned out, went from SL7 setup to a Roval 1pc cockpit setup, both were done with 3d printed spacers.
- wheelbuilder
Great color.ViperFFM wrote:Very happy how the assembly turned out. Wasnt happy with all the 3D-printed spacers floating around so sticked with stocked; tidied up the cables under the old venge stem and we are good to go. Red/Rose latex slip will be changed for black one
Looks amazing!
I kinda like the latex tube on the fork as its a subtle way of showing you race the bike. Didnt know there is black latex tubes tho, might look cleaner on some bikes.
Cool paint and looks great!Shanghaicyclist wrote: ↑Fri Jan 26, 2024 4:29 amPretty happy with how my setups turned out, went from SL7 setup to a Roval 1pc cockpit setup, both were done with 3d printed spacers.
