Where is new SRAM Red?
I've got the perfect build for this but can't help but wonder, why have we not see new SRAM Red? It's so odd for the top groupset to be the most outdated. We're looking at 4 years since the last update.
Maybe manufacturing problems? It's sells less so not a priority? Waiting to see if road bikes adopt UDH so they can quickly rollout a UDH Red groupset to get everyone on new frames?
Perhaps a major update?
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-SRAM Red viewtopic.php?f=10&t=174523
February 2019 is already 5 years ago? I have to check my calendar. It will come, don't worry
Dum spiro spero
my bike: viewtopic.php?f=10&t=130302
Sorry, 4. Feels like 10.
- eucalyptus
Lighter, quicker gear shifting and more reliable shifter electronics (battery issues very common on the shifters, not derailleur).
Otherwise axs is already rock solid.
Pretty curious what they can still improve as well. Wasn't there a topic on (potential) improvements of the new flagship group?
Also I believe current stock is an issue. Why pay double for the most outdated groupset of the 3? Not saying the new groups are a massive difference, but the Force D1 is super cheap at the moment.
- wheelsONfire
Question is if it's even nearly possible the crankset with integrated fd is the next thing!?
It would be so far out. Or perhaps a crankset/chainrings which correct chainline to a more optimal angle.
Talking drivetrain i guess there's huge things cooking. Question is how complex such a system can be and still be reliable.
Bikes:
Open *UP* (2016.04.14)
My quesiton is will it be the first road group utilizing UDH? My guess is Sram will need time to work with bike manucturers if the company wants to go with UDH for road.
Yeah, I have been wondering this too. There are a lot of issues with UDH on road bikes though. Primarily the axle spacing being wider which means higher chance of hitting your foot on the chainstay. I personally hope they do not put UDH on road bikes because overnight, you just made millions of bikes obsolete for a trivial benefit.ipenguinking wrote: ↑Wed Oct 11, 2023 7:23 pmMy quesiton is will it be the first road group utilizing UDH? My guess is Sram will need time to work with bike manucturers if the company wants to go with UDH for road.
That ship has already sailed, I guess, as the first new models with UDH have been released this year (Ridley Falcn and Dean Fast) - and Im not sure Ridley would take that step just for the standardized hanger.rollinslow wrote: ↑Wed Oct 11, 2023 7:28 pmYeah, I have been wondering this too. There are a lot of issues with UDH on road bikes though. Primarily the axle spacing being wider which means higher chance of hitting your foot on the chainstay. I personally hope they do not put UDH on road bikes because overnight, you just made millions of bikes obsolete for a trivial benefit.
Then you can fully expect that the industry will move in that direction. It has to. Just to fú¢k everyone over (yet again).rollinslow wrote: ↑Wed Oct 11, 2023 7:28 pmYeah, I have been wondering this too. There are a lot of issues with UDH on road bikes though. Primarily the axle spacing being wider which means higher chance of hitting your foot on the chainstay. I personally hope they do not put UDH on road bikes because overnight, you just made millions of bikes obsolete for a trivial benefit.ipenguinking wrote: ↑Wed Oct 11, 2023 7:23 pmMy quesiton is will it be the first road group utilizing UDH? My guess is Sram will need time to work with bike manucturers if the company wants to go with UDH for road.
And more reliable FD shifting. And 16t front ring jump. And longer battery life.eucalyptus wrote: ↑Wed Oct 11, 2023 3:32 pmLighter, quicker gear shifting and more reliable shifter electronics (battery issues very common on the shifters, not derailleur).
Other than everything, it's perfect already.
I would change that to easier FD setup because FD shifting is reliable when it's been set up right. I actually think they've achieved that anyway with the new Force FD and chainset: quick and easy to set up and not a hint of a drop IME.
No thanks. I'm very happy with AXS ratios providing smoother transitions at front and requiring fewer compensation shifts.And 16t front ring jump.
Eh? Battery life is not and has never been an issue. Charging only takes an hour and can be easily done off the bike. You can carry a spare if you're paranoid, but it's not necessary. It's less of a burden than charging your head unit. Having a failover system where you can swap batteries if the RD goes flat is a reassurance you don't get with Di2. BTW, since I beagin running eTap in 2017, I've only had a flat RD once and that was in my first month of ownership when I hadn't quite got it yet.And longer battery life.
It's actually pretty damned closeOther than everything, it's perfect already.
I would like to see compatibility with existing AXS maintained, improved pad clearance, buttons on hoods, weight savings, gold chains
