Enve 1 Piece Cockpit
Looks like Tadej was running the 1-piece cockpit from Enve. Any ideas on when the public will get it?
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
you can ? you just need to get a Enve custom frame as well. Although this new one has a slightly different shape then the older 1 piece.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
"Available later this year" https://www.instagram.com/p/CuKDKeKLsdk ... BiNWFlZA==
They are a new product based off the Aero bar vs. the existing 1-piece which is based off the similar but different AR bar.
Yep the bar looks great, saw a reply on Instagrma that it uses the same internal wiring system of the melee if that helps any one.
I think i am definitely going Roval now for my SL7. This cockpit does look better though.
I've become an Enve fanboy for handlebars, now running two different sizes of the SES Aero bars on four of my bikes, on both dirt and road. They also seen to get/lead the trend in the narrow options, and I honestly wouldn't be surprised if they had an even narrower option than the 35cm/40cm version. Something like a 32cm hoods, with a flare to 38cm. Also would love to see the integration of an angle adjust system like on their Aero Road stem, although combining that with the In-Route system might be a tall ask. I suppose you'd also then be sacrificing the correct bar level for lever positioning... So lets atleast hope for something steeper than -6 degrees.
Pogi's new bar isn't as flared as his previously aero handlebar.
Even the shape of the drops seems to be a bit different. For pro racing, the 5cm flare is a bit too much. Trek nailed it with a 3cm flare.ome rodriguez wrote: ↑Tue Jul 04, 2023 4:07 amPogi's new bar isn't as flared as his previously aero handlebar.
Can you explain what is it that makes 5cm flare too much? How that effects pros more than others, etc?pmprego wrote: ↑Tue Jul 04, 2023 7:45 amEven the shape of the drops seems to be a bit different. For pro racing, the 5cm flare is a bit too much. Trek nailed it with a 3cm flare.ome rodriguez wrote: ↑Tue Jul 04, 2023 4:07 amPogi's new bar isn't as flared as his previously aero handlebar.
I love the aero position I get on my hoods, but I definitely note the lack of stability in a sprint in the hooks, even with the 5cm (probably around 3cm in the hooks) flare. I don't see why a pro would want even less?
My reasoning:Nereth wrote: ↑Wed Jul 05, 2023 6:10 amCan you explain what is it that makes 5cm flare too much? How that effects pros more than others, etc?pmprego wrote: ↑Tue Jul 04, 2023 7:45 amEven the shape of the drops seems to be a bit different. For pro racing, the 5cm flare is a bit too much. Trek nailed it with a 3cm flare.ome rodriguez wrote: ↑Tue Jul 04, 2023 4:07 amPogi's new bar isn't as flared as his previously aero handlebar.
- sprinting is a max speed event thus aero is more important
- sprinting is done on the drops
- wider is slower
- track people sprint in very narrow bars - faster
- this applies the most for pros because they are the one doing 60/70kmh sprint finishes
Thus, a pro, at 60kmh sprinting for the line wants to be the most aero version he/she can be. For that, if they can go narrow, they should (again... Track people).
If you look at the number of riders with turned-in hoods, there's clearly a desire for quite flared handlebars in the peloton - probably dims similar to what Enve has with the SES Aero bars. I hope these follow.
I'm not sure comparing road sprinter's needs to track sprinters is particularly useful here, I won't dispute that there are aerodynamic benefits to going narrower but there's a big functional aspect as well - a lot of tracking sprinting actually happens when the riders are sat down so stability is inherently greater. In a road sprint, there's a whole load more standing sprinting - so side-to-side stability is beneficial, and allows for more leverage.
It seemed to me that the flare on pog's bar is smaller. Maybe it isn't. Let's wait for the official specs and conclude.Nohands83 wrote: ↑Wed Jul 05, 2023 8:57 amIf you look at the number of riders with turned-in hoods, there's clearly a desire for quite flared handlebars in the peloton - probably dims similar to what Enve has with the SES Aero bars. I hope these follow.
That would great if it holds true. Did they tell you which brands ENVE was making the matching headset spacers for too?
