squiresm
by squiresm on Sun Mar 03, 2024 5:42 pm
wheelbuilder wrote: ↑Sat Mar 02, 2024 8:59 am
squiresm wrote:Hey guys, I’m looking to build an SL8 with Roval cockpit and would appreciate any advice. First time with a Specialized bike so I’m a bit unsure with sizing.
Currently I ride a size 56 Emonda with a 90x400 integrated Bontrager cockpit. If I were to build a 56 SL8 with the Roval bars, any views on whether the same size bar and stem would be suitable? I’m aware the bar reach on the Roval differs vs the Bontrager, so wasn’t sure if a longer stem would be advisable.
I visited my local Specialized shop to get their input which was basically that the two brands are the same in terms of size and therefore I should just keep the same measurements, but they didn’t fill me with confidence so I’d appreciate any other views!
Not sure if it applies to integrated, but some Bontrager bars have 100mm reach. Way more than most competitors so take that into account if needed fit wise.
Thanks, yeah that's the case for the integrated bars too, whereas I've seen the Roval is 75mm.
So if I'm interpreting the numbers correctly, does that effectively imply I'd need a stem that's 20mm longer to create the same fit, given the Tarmac frame reach is approx 5mm longer? Or would it not be that linear in practice?
wheelbuilder
by wheelbuilder on Sun Mar 03, 2024 6:19 pm
squiresm wrote:wheelbuilder wrote: ↑Sat Mar 02, 2024 8:59 am
I'm of the camp that says it is that linear. I can really tell the difference in my own experiences and fits. I've always liked Bontrager bars for that extra 20 and sometimes 30mm.
Sander7721
by Sander7721 on Sun Mar 03, 2024 8:08 pm
mistermistermayor wrote:https://tipartstitanium.com/products/ti ... 6122344748
anyone used this topcap bolt and know if it sits more flush? looks like it based on their photos, but then again specialized's own pictures don't show the issue so can't be sure. cheaper than the other options I've seen discussed here so curious if it'd solve it.
That’s a bolt set only with no cap. Bolt spits the same Extralite bolt is tidy
SL8 Maganta 54CM 6kgs
Winspace SLC 2.0
squiresm
by squiresm on Mon Mar 04, 2024 12:16 am
wheelbuilder wrote: ↑Sun Mar 03, 2024 6:19 pm
Thanks, that's helpful to know. I've been on Trek bikes for about 6 years now and haven't really sampled many other brands in terms of equipment and sizing, so appreciate your input!
BudhaNL
by BudhaNL on Tue Mar 05, 2024 9:58 pm
Sander7721 wrote: ↑Sun Mar 03, 2024 8:08 pm
Looking for the best solution for my RRC at the moment. If I read the thread well there's the following options for a flush appearance:
- Be lucky with the original bolt from the cockpit
- Source an SL7/Aethos bolt which will sit flush
- The Extralite bolt (can't find it bolt only unfortunately on their website, not under spare parts?)
- That tiparts titanium bolt (also available as single bolt only) & hope that it will fit more like SL7/Aethos bolt then RRC bolt
The tiparts titanium bolt is available in oilslick which would complement my Venge with oilslick logo's rather well so that's my preference. f it would fit flush, that is.
Sander7721
by Sander7721 on Tue Mar 05, 2024 10:20 pm
BudhaNL wrote:Sander7721 wrote: ↑Sun Mar 03, 2024 8:08 pm
Where are you located
I got an extralite bolt bought it from a French website
I bought the HypercCap to get the bolt
Winspace SLC 2.0
Seamanatorr
by Seamanatorr on Tue Mar 05, 2024 10:30 pm
BudhaNL wrote: ↑Tue Mar 05, 2024 9:58 pm
For my SL7 I have treid the following
-SL7 S-Works stem bolt from my build
-Aethos top cap bolt
-Better Bolts titanium top cap bolt
-Stock Roval Rapide bolt
-Extralite bolt
The Extralite bolt is the only one that works. Do we think the Seat Tube Angle based on size is the issue? When my LBS installed the combo using either the SL7 bolt or combo bolt it looked terrible.
S-Works SL7 RTP
Sander7721
by Sander7721 on Tue Mar 05, 2024 10:31 pm
Sorry guys the app playing up so multiple posts.
I upgrade these last year the Extralite bolt should be black but that's what was sent
- IMG_1863.jpeg (53.44 KiB) Viewed 685 times
- IMG_1862.jpeg (54.62 KiB) Viewed 685 times
- IMG_1861.jpeg (44.05 KiB) Viewed 685 times
- IMG_1858.jpeg (41.43 KiB) Viewed 685 times
Winspace SLC 2.0
BudhaNL
by BudhaNL on Tue Mar 05, 2024 10:55 pm
Sander7721 wrote: ↑Tue Mar 05, 2024 10:20 pm
I'm in the Netherlands. You're UK-based right?
mistermistermayor
by mistermistermayor on Tue Mar 05, 2024 11:42 pm
I wish there were an option besides the extra lite bolt. I don't love the fact that it's hollow and can let water etc into the fork. Based on seeing someone else file down their stock bolt to get it flush it seems like a bolt with just a slightly different head shape would do the trick, so was hopeful the tiparts might have just that shape. sounds like the betterbolts one is the same shape as stock so it's probably not likely unfortunately. not too expensive to just try and see I suppose!
