Roval Rapide Cockpit
- gorandotcom
Has anyone installed the Roval Rapide Cockpit on an sl7 yet?
S-works Tarmac SL8
There's been a bunch of mini-threads in the SL8 and SL7 threads but long story short is that it is indeed lighter than the separate stem+bar combo but the cockpit doesn't ship with the required transition spacer to make installation smooth on the sl7. Those spacers won't ship until July/August and even then it's a dealer part order.
I have the bars on the way and got my dealer to pre-order the part.
Sanders2177's photo attached.
- Attachments
- IMG_9412.jpeg (54.09 KiB) Viewed 54261 times
I guess people don't want to (I wouldn't) disconnect brake hoses and rebleed the system to swap the headset cover. And many may not have that headset cover anymore.
keno190 wrote: ↑Wed Jun 14, 2023 1:14 amThere's been a bunch of mini-threads in the SL8 and SL7 threads but long story short is that it is indeed lighter than the separate stem+bar combo but the cockpit doesn't ship with the required transition spacer to make installation smooth on the sl7. Those spacers won't ship until July/August and even then it's a dealer part order.
Yep that's my SL7 and no not installed the bars as waiting on Racewear.co for some spacers first so hopefully buy the end of this month perhaps .
Specialized have no firm dates for the spacers yet and cannot be bothered to swap bars twice
S Works SL8 54cm 5.94kgs
Winspace SLC M Ultegra R8150 no idea of kgs
Racewear has his spacer up
https://www.racewaredirect.co/shop/spec ... er-spacer/
Now can he thin it out by 10mm so that people with slammed stems can use the new bars?
2022 Specialized S-Works SL7 I Ultegra R8170 I Princeton Carbonworks 6560
2012 Cannondale CAAD 10 I 105 R5700 I Zipp 404s
Some pics of it in the wild -
- robbosmans
- Moderator
- Contact:
That doesn’t looks good imo
- gorandotcom
I agree that does not look good.
S-works Tarmac SL8
It specifically mentions that the image includes a factory SL7 spacer which is not included... And that the transition adapter itself is only 10mm tall, so no he can't reduce that to zero... LOL.
This handlebar sure does seem like a miss... The fact that they release it before you can even get the proper adapter to make it fit well onto the bike that 90% of them will end up on is mind boggling. I can't help but wonder if there were some delays in releasing an SL8 and they had this bar already done, so they launched it prior to the SL8 in which its designed around???
Regardless, they also seemed to miss the mark with the sizing, with 38cm being the narrowest. Unless as its been discussed in the SL8 thread, their waiting to release a 35/36cm version on the SL8 so they can tout it as 5% more aerodynamic than the SL7( of which 4% of that savings will be the narrower bar).
