Roval Rapide Cockpit
Cattiy
by Cattiy
Says who?
req110
by req110
Cattiy wrote:
Mon Feb 12, 2024 5:22 pm
The SL8 fork steerer and the Rapide cockpit have such a tight fit...I literally have to rotate and force the Cockpit onto the steerer. Never ever in my life had a stem such a tight fit! A normal S-Works SL7 gets much easier onto the steerer.
It is so tight I see no way to adjust the headset play...What a piece of sh** from Specialized for several thousand dollars...
Mine was tight as well, so i sprayed bit of water there and pushed cockpit onto the fork with front wheel in place pushing it from top to bottom, but gently enough.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
fastforageezer
by fastforageezer
Cattiy wrote:
Mon Feb 12, 2024 6:20 pm
Says who?
Says basic, common bike mechanical skills. The tire lever trick is hardly a secret. Only took a gentle spreading action to get my Rapides on, didn't even need to remove the bolts, just made sure they were a bit loose.
GONE4ARIDE
by GONE4ARIDE
Did you install the expander in the steerer before or after mounting the cockpit?
Cattiy
by Cattiy
Beforhand, like the manual says.
JT508
by JT508
Hello,
Any 40-110 or 38-115 available anywhere? :)
thanks
LeMillion
by LeMillion
JT508 wrote:
Fri Feb 16, 2024 12:15 am
Hello,
thanks
Just came back in stock here: https://www.performancebike.com/special ... ?v=1482968
cooper58
by cooper58
Received my forged carbon fiber top cap from Thailand (Instagram > specialized_townintown).
Upcountry
by Upcountry
Just a PSA... 38cm x 115cm are in stock for the moment...
https://www.specialized.com/us/en/roval ... YFI.NHdUx9
Update: 1 hour later...Annnndddd they're gone.
BikeTyson
by BikeTyson
Upcountry wrote:
Tue Feb 20, 2024 5:37 pm
Lol, I was literally just going to post that meme. Sold out quick.
Edit: I was able to snag one but I'm thinking it's not going to work. I'm riding a 40/120 right now. The width I think will be fine but I'm losing .5 cm reach and .5cm stem.
Vuong05
by Vuong05
BikeTyson wrote:
Tue Feb 20, 2024 6:49 pm
Sold out already... 😢
Current Stable. Evo (Storm Trooper) : 5.39kg | Alchemy Eros : Heavy (7.25kg) I Specialized Allez Sprint 2022 : Heavy (7.62kg)
Sander7721
by Sander7721
Sold out already... Image
These have popped up today in UK
All sizes
SL8 Maganta 54CM 6kgs
Winspace SLC 2.0
Sander7721
by Sander7721
cooper58 wrote:
Sat Feb 17, 2024 6:16 pm
Whats is your thoughts on this cap?
Had on shipped to the UK in 3K carbon last year and paired it with an Extralite Bolt
Winspace SLC 2.0
Sander7721
by Sander7721
Also anyone running Avian Canary/Falcon or EXS bars?
Was considerimg maybe swappimg to EXS from Rapides as looks clean
Any thoughts or pictures would be good
Winspace SLC 2.0
Upcountry
by Upcountry
Sander7721 wrote:
Fri Feb 23, 2024 1:20 pm
See relevant threads for those cockpits...
viewtopic.php?f=3&t=163899&start=225
viewtopic.php?f=3&t=170466&start=480
