Specialized S-Works Tarmac SL8
No fine tooth blade. Just a regular carbide blade. It cuts through carbon like butter. No fraying and a perfectly square cut with no additional finishing needed.
If you don’t believe it, just try it on a piece of scrap carbon steerer. The whole process takes 30 seconds.
This may not be the best place to ask this, but a lady in our club has a SL8 with the Roval Rapide handlebar (the aero handlebar not the integrated cockpit) and is doing a triathalon in May. Are there clip on aerobars that she can put on with the Rapide bar? If so what options are out there?
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
Best bet for her is the stem mounted SpecializedMocs123 wrote: ↑Wed Mar 20, 2024 2:11 amThis may not be the best place to ask this, but a lady in our club has a SL8 with the Roval Rapide handlebar (the aero handlebar not the integrated cockpit) and is doing a triathalon in May. Are there clip on aerobars that she can put on with the Rapide bar? If so what options are out there?
ITU Venge Clip-on Aerobar. Just check first the dimensions of the Tarmac stem if it's similar to the Venge stem.
viewtopic.php?f=3&t=158665
Here's my take on my rapide cockpit with clip-on aerobars.
viewtopic.php?f=10&t=173649&p=1858620#p1858620
That is very cool. Have you considered selling them?ome rodriguez wrote: ↑Wed Mar 20, 2024 6:18 amHere's my take on my rapide cockpit with clip-on aerobars.
It won't fit as-is, but there's an adapter clamp for the SL7 stem. SKU 21021-2003 ITU/TT/TRI CLIP ON TARMAC CLAMP BLKome rodriguez wrote: ↑Wed Mar 20, 2024 6:01 amBest bet for her is the stem mounted Specialized
'24 S-Works Tarmac SL8 RTP - soon™
'22 Tarmac SL7 Expert | Ultegra R8100 | Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'18 Epic HT Comp Carbon WMN
'18 TCR Adv Pro 1 Disc
'19 Diverge E5 Comp
Whoever built my pro kindly sized my chain long.
When I put an 11/34 on I bought a dura chain, sized it myself. Turns out it's the same length as the one that came on the bike.
That said, even if it's a little small it's unlikely to be an issue if you avoid big-big
