NEW Trek Emonda ALR 2023
openwheelracing
by openwheelracing
What are these spacers/dust cover and where can I get them?
fizzaz
by fizzaz
That looks like the top cover that they include with the frame meant for the RCS stem, but the spacer just below this stem looks like the oen meant for carbon SL7 emonda? I think? It actually looks pretty clean.
robertbb
by robertbb
I can't get my head around these half-way integrated cable solutions.
Trek, Merida, now Giant. Who thought leaving a gaping hole at the front of the bike for water and dust ingress was a good idea? *facepalm*
At least on older frames where the brake hoses entered the frame itself, you had rubber grommets providing a modicum of weather protection and sealing.
If you're going to integrate the cables just run them fully internal and be done with it.
fizzaz
by fizzaz
I've been on this type of system for several years now and I have seen no problem whatsoever of shortened bearing life. It just isn't a problem that everyone assumes. To me, it's the best of both worlds when it comes to "hidden" cables.
openwheelracing
by openwheelracing
What do you all think? 3D printed? Trek OEM?
fizzaz
by fizzaz
Definitely 3d printed and pretty sure I want it.
rothwem
by rothwem
So I've got a new ALR frameset on the way. Would it be a crazy thought to build one of these with the Tarmac SL7 stem? The upper bearing cap looks a lot like the Allez Sprint's:
justdank
by justdank
rothwem wrote:
Thu Feb 08, 2024 9:16 pm
I've been waiting for someone to post this. I like how the stem has that piece that bolts down and keeps the cables tidy.
With decent cable management can get just as clean of a look with a traditional stem as well.
rothwem
by rothwem
So I got my frame in and started putting parts on it and realized that the dropouts are a little wonky on my bike--the rear needs to be spread a bit to get the hub in and in the front, there's a solid 5mm gap on either side of the hub endcaps between the fork drops.
Should I be worried about this? The wheels do go on and tighten up okay but my other bikes aren't like this.
Also, there's a giant gap between the top of the headtube and the bearing cap, did I put this together wrong? I haven't run any cables yet, just wanted to mock it up first. EDIT: just realized this is "Normal". Wtf.
The grey paint looks awesome though.
rothwem
by rothwem
So at this point I feel like I'm just talking to myself, but I wonder if this would work as a lower stack option for the headset cable routing:
https://shop.cervelo.com/products/mtb-bearing-cap
Its the headset cable routing from the Cervelo ZHT-5, which uses a straight 1.5" head tube with a regular 1 1/8" -1 1/2" fork just like the ALR does.
Aw *f##k* it, I'm going to order it and try it out, its only $20.
justdank
by justdank
Looks like it will. The Deda system can also lower it a lil bit.
Keep us posted about the Cervelo cap, could be a decent option.
justdank
by justdank
rothwem wrote:
Tue Feb 13, 2024 4:48 pm
As far as the frame I had manufacturing issues that got resolved when I brought it to the LBS and sent out for warranty. If you're not 100% about it had the shop look it over. Fork seems normal as it would suck in with the ThruAxle.
That headset space does seem a little bigger than most(including mine) Are you sure its in there peoperly with the bearings preloaded?
TobinHatesYou
by TobinHatesYou
fizzaz wrote:
Wed Jan 24, 2024 5:14 pm
It’s possibly a revised FramesAndGear one.
https://framesandgear.com/products/fram ... er-my-2023
justdank
by justdank
rothwem wrote:
Fri Feb 16, 2024 8:10 pm
Looked at the tech doc, and it does look like it will work.
TobinHatesYou
by TobinHatesYou
The Cervelo cover and compression ring might work. The Deda DCR cover and 36/45deg compression ring will almost certainly leave a huge gap between the cover and HT.
