NEW Trek Emonda ALR 2023
fizzaz
by fizzaz
rothwem wrote:
Mon Mar 18, 2024 9:56 pm
fizzaz wrote:
Mon Mar 18, 2024 8:48 pm
I want to dig back up the possibility of the Sworks Tarmac Sl7 stem. I'm thinking it is possible and would fit the look of the bike really really well.
That stem is the best solution for semi integrated routing available in terms of weight and functionality.
Since this is weight weenies, I should mention that the SL7 stem is an f-ing boat anchor. It does look pretty clean though.
It is not lightweight, but it is far and away better than the Trek or FSA stems that are somehow even worse. At least the spacers integrate into an aero shape.
Does anyone know of an adapter to a round top cap like the alr?
rothwem
by rothwem
The position with the 6 degree stem wasn't low enough--I knew it wouldn't be when I used the stock spacer. My $20 Kalloy Uno -17 degree stem came in and I installed it. I haven't had a chance to ride it outside with the -17, but the position feels good on the trainer.
It does look stupid though. Is it weird that I kinda want to sell this bike because it looks dumb?
BikeTyson
by BikeTyson
rothwem wrote:
Fri Mar 22, 2024 3:04 pm
I'm not sure what looks dumb here, but if you want to offload this "stupid" bike what size is it? I don't mind looking dumb.
rothwem
by rothwem
BikeTyson wrote:
Sat Mar 23, 2024 2:53 pm
Hah, it's a 58cm. I'm mostly referring to the -17 stem that is drooping down because the steerer tube is steeper than 73*, it looks a bit awkward to my eye.
Finally got a chance to ride it though, and -17 is too low. Going to stack some spacers for now and it's going to look weird until I decide what the proper stem angle should be.
I'll give it a couple months before I make a decision on selling it, I need to get the contact points in the same spot as my Cannondale and go from there.
Amerikaner
by Amerikaner
Thomson X2 and Pro PLT stems are available in 10 degrees...with a 120mm stem that would be about an 8mm drop from as 6 degree stem.
rothwem
by rothwem
Amerikaner wrote:
Sun Mar 24, 2024 11:25 pm
Cool, thanks for the heads up. I guess when the stem gets long (I'm using a 130mm) the angle makes a ton of difference. If my trig is right, a -17° stem is 24mm lower than a -6° on a 73.8° HTA. A 12° would be 13mm lower and a 10° would be 9mm.
I put a 10mm spacer under the 17 degree stem and feels pretty good, so it looks like I need a 10-12° stem.
wheelsONfire
by wheelsONfire
rothwem wrote:
Tue Mar 26, 2024 3:21 pm
I also ride a -17 stem. Wait unil you get a -20 stem :lol: , then we can talk of the looks!!
Part from that, you should keep the bike. If you want to sit more upright, you can always swap stems.
I would easily keep it if i had it.
Bikes:
Open *UP* (2016.04.14)
apr46
by apr46
justdank wrote:
Wed Mar 13, 2024 10:18 pm
Keep us updated on the Domane ring top cap, I just grabbed one from the trek store. Much easier to acquire than the 36 c-ring
It's orderable. I have a couple on hand as well.
https://aprotobike.com/products/copy-of ... s-acr-stem
justdank
by justdank
apr46 wrote:
Sun Mar 31, 2024 10:16 pm
Nice work, looks clean.
Do you have any photos of it on the bike?
raggedtrousers
by raggedtrousers
Not sure if this was wholly clarified early in the thread, but am I right in thinking Trek's stated stack height does not include the bearing top cap, which is 15mm (and in a 54 will therefore add ~13 mm to the stack height)?
I called Trek UK for clarification and they, ahem, weren't clear. :noidea:
If it doesn't include it, I might need to drop down a size. Any definitive guidance would be appreciated - thanks.
fizzaz
by fizzaz
It does not include it. All new integrated frames have this problem.
rothwem
by rothwem
raggedtrousers wrote:
Fri Apr 12, 2024 10:46 pm
Yeah, like the poster just above said, it doesn't include it, which is annoying. It's kinda messed up my fit on this bike. I've got a -12 stem on the way, but it makes the advertised "H1.5" fit the same as the old H2 fit.
And btw it's more like 18mm of stack.
At some point I need to suck it up and accept I'm going to have to rewrap my bars and bleed my brakes and just get the aprotobike low stack one.
raggedtrousers
by raggedtrousers
Thanks - exactly the situation I'm trying to avoid...
morrisond
by morrisond
What is the best solution to make an ENVE In-Route system Bar/Stem or Stem work with the ALR so all the cables are completely hidden? Just use ENVE's top Cap and Spacers?
apr46
by apr46
justdank wrote:
Fri Apr 05, 2024 7:02 pm
Still waiting on complete build photos. They look pretty much the same as the ones that Flicker Racing has on their bikes. Its slightly lower profile, but gap from the headset to the frame is a little more variable.
