Real Parts Weights - Scale Shots
RyanH
by RyanH
Since it has been too much of a lift to get the listings working again, I figured the next best thing would be a resource to aggregate actual parts weights with a scale shot. This information exists throughout the forum but it's not structured in a way that is optimized for search engines. So, use the below template when posting parts and this way we can have a resource of actual component weights.
Bicycle Part: [Year Manufacturer Model]
Size/Length: [e.g. 170mm BB30 cranks]
Includes/Excludes Parts: [Includes spacers for BB]
Weight (in grams): [xxxx g]
Notes: [Optional - additional details about item if beneficial]
Scale Shot: [img URL]
RyanH
by RyanH
Bicycle Part: 2022 Prestacycle 11-32 11s Shimano Cassette
Size/Length: 11-32 11s
Includes/Excludes Parts: Excludes lock ring
Weight (in grams): 212g
Scale Shot:
DHG01
by DHG01
Bicycle Part: 2022 Bdop 11-32 11s Shimano Cassette
Includes/Excludes Parts: Includes lock ring
Weight (in grams): 129 grams
Scale Shot:
DHG01
by DHG01
Bicycle Part: 2022 Syncros Belcarra V 1.0 TT Saddle
Size/Length:
Weight (in grams): 183g
Scale Shot:
nickf
by nickf
Bicycle Part: 2022 Growtac Equal mechanical calipers
Size/Length: Flat mount
Includes/Excludes Parts: with pads, no hardware
Weight (in grams): 275g /pair
Scale Shot:
Aeo
by Aeo
The images should be uploaded via the forum and not embedded from third party websites with a varying degree of reliability. Too many threads in the forum become useless because the pictures are not available
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
ArtifactsInMotion
by ArtifactsInMotion
Bicycle Part: 2022 Specialized S-Works Romin Evo
Size/Length: 143mm
Includes/Excludes Parts: n/a
Weight (in grams): 130g
Notes: n/a
Scale Shot:
Romin Evo 143mm
Romin Evo 143mm
'22 Orbea Orca Aero 57cm, DA92, Bontrager RSL62, GP5KSTR 28mm, Roval Rapide Cockpit, SLR Superflow Carbonio, 7.8kg
C36
by C36
Bicycle Part: 2021 Mavic Comete Ultimate shoes
Size/Length: 42 2/3
Includes/Excludes Parts: weighted with 83g cleats installed
Weight (in grams): 582g with cleat, 499 without
Notes:
Scale Shot:
wltz
by wltz
Bicycle Part: 2021 Shimano BR-R9270-F
Size/Length: DA 9270 front caliper
Includes/Excludes Parts: includes mounting HW, L03A pads and springs, bleed block
Weight (in grams): 135 g
Notes: pads and spring are 16g, bleed block (unexpectedly heavy) 9g, so 110g net weight
Scale Shot:
wltz
by wltz
Bicycle Part: 2021 Shimano BR-R9270-R
Size/Length: DA 9270 rear caliper
Weight (in grams): 125 g
Notes: pads and spring are 16g, bleed block (unexpectedly heavy) 9g, so 100g net weight
Scale Shot:
ArtifactsInMotion
Bicycle Part: Silca ti bottle cage bolts
Size/Length: torx T25 M5x12
Weight (in grams): 1.5g ish (7g for 4)
Notes:
Scale Shot:
C36
by C36
Bicycle Part: J&L Ti hollow t25 screw
Size/Length: torx T25 M5x15.5
Weight (in grams): 1.02 (6.15 for 6)
Notes: https://www.ebay.fr/itm/202323006852?mk ... media=COPY
Scale Shot:
ArtifactsInMotion
Bicycle Part: Runwell Japan x Tokubetsu top cap
Size/Length: standard
Includes/Excludes Parts: excludes bolt
Weight (in grams): 6g
Scale Shot:
Yoln
by Yoln
RyanH wrote:
Wed Sep 28, 2022 9:39 pm
Scale Shot:
This looks very very much like a Edco/Rekon cassette (weight matches as well), is there any link between Prestacycle and the others?
#RETIRED# Lynskey “the Do-it-all Helix” 🧬:https://tinyurl.com/bdmb5y24
wltz
by wltz
Bicycle Part: 2022 Prime Primavera Aero Road bar
Size/Length: 38 cm c-c hoods and drops
Weight (in grams): 229 g
Notes: the clamping area has almost 5mm of wall thickness, the beefiest I've seen on any bar
Scale Shot:
