Giant Propel 2023
Don't know, maybe details about usage of recommended grease or paste at speicific locations of the bike ( seat post comes to mind - so in doubt I'll just paste it up)
May be different from orther manufacturers.
Then the cable guide at the fork - there's a sheet that describes how to install it but not how to actually use it.
And there are also other bits and pieces supplied with the frameset that kind of confused me. Like a plastic strip. And the di2 battery holder wasn't too obvious either...
Did you install handlebar yourself, what about cable routing?
Is it Lexon vero you use?Seven1816 wrote: ↑Fri Dec 08, 2023 2:39 pmIMG_2678.JPG
I am taking my time with my build, I am close to finishing, just waiting for some Ti bolts to lighten the build keeping true to the weight weenie mentality, but here is a pic of my bar and stem set up, total mish mash from three different manufacturers, compression spacer is Bigrock, spacer is Vyce HB05, bar is Lexon. I am 100% happy with the setup as it is clean as green.......
I have to say the D steerer shim makes a difference on flex, no matter what 31.8mm ROUND stem you use please use a shim! It should save you heartache in the future.
LBS did it. They said it was not anything more complicated than other integrated bars.lukaszzsch wrote: ↑Fri Jan 12, 2024 4:39 pmDid you install handlebar yourself, what about cable routing?
At least for frames only, giant should supply the D spacer in the box.
Supplied by EXS with handlebar, including top transition spacer. Giant does not provide it, nor approves such solution. Original alu stem is not perfect also, it scuffs the fork when recommended torque is applied.
Yes, EXS Aerover looks very clean, I am happy with end result!
I found this on instagram, it seems to be a combined dustcover and cable router.
See picture 2 for end result.
https://www.instagram.com/p/CzAAuMiymR3 ... mg_index=1
Nice setup!Seven1816 wrote: ↑Fri Dec 08, 2023 2:39 pmIMG_2678.JPG
Where did you get the shim? Where did you get that spacer? Which Lexon bar is it?
Thank you, much appreciatedsombrero wrote: ↑Mon Jan 15, 2024 5:55 pmI found this on instagram, it seems to be a combined dustcover and cable router.
new CADEX integrated bar for Propel pro team, see today in Michael Matthews IG accout https://www.instagram.com/p/C2MWNDWo_Nw/
NOT IN STOCK for the moment
- Attachments
- Immagine.png (643.44 KiB) Viewed 1901 times
Hopefully they have long and narrow options!coverstem wrote:new CADEX integrated bar for Propel pro team, see today in Michael Matthews IG accout https://www.instagram.com/p/C2MWNDWo_Nw/
