Giant Propel 2023
Maddie
by Maddie
I made a spontaneous decision to order a Propel Advanced Pro frameset in size M. This particular frameset is not available in Switzerland so I had to order it in Italy. I should be able to pick it up in the store mid February. Like this I can also profit from the much lower VAT in Switzerland since I can claim it back when the frame is exported from Italy. Difference is 22% vs 8.1%. The shop where I ordered was/is very helpful since I bought a TCR frame from them just two weeks ago. And the Swiss Franc is very strong at the moment which sweetens the deal even more.
The plan is to strip the frameset to bare carbon and just go for unobtrusive logos and clearcoat. I will add Farsports hooked wheels in 50/30mm, probably with carbon spokes, EXS Aerover in 360/110mm (thanks for the pics, Mindflash) and a mix of DA and Ultegra 12s groupset with Red cranks. Not in a hurry with this one, first I need to get the frame and then strip it. That will take a couple of weeks anyway.
Not sure at this point what I will do with the TCR frameset. It is a lot heavier than I expected at 1094g without any hardware.
Tooslow
by Tooslow
"Not sure at this point what I will do with the TCR frameset. It is a lot heavier than I expected at 1094g without any hardware."
Which frame is 1094g, the TCR or Propel?
BikeTyson
by BikeTyson
coverstem wrote:
Wed Jan 17, 2024 3:41 pm
new CADEX integrated bar for Propel pro team, see today in Michael Matthews IG accout https://www.instagram.com/p/C2MWNDWo_Nw/
NOT IN STOCK for the moment
Looks like little plugs for climbing shifters built in. Or maybe a different way of routing cables externally.
mike
Resident Pro
by mike
the propel looks fantastic. i saw one in person and giant has come a long way since the once tcr days
Eterna7m
by Eterna7m
Tooslow wrote:
Wed Jan 24, 2024 5:10 pm
My propel pro advanced in M was 1024g, so I think he means the propel
Maddie
by Maddie
Correct, my TCR weighs 1094g. I don't know about my Propel yet since I haven't received it.
Eterna7m
by Eterna7m
Maddie wrote:
Wed Jan 24, 2024 8:45 pm
Ok, damn. Then that TCR is heavier than I thought. Which size?
Maddie
by Maddie
Same here!
It's also size M
Eterna7m
by Eterna7m
How does the stripping to bare carbon work with the warranty?
Tooslow
by Tooslow
I'm surprised at the weight of the TCR & the Propel!
GrassQ
by GrassQ
Some Propel weights MY23
Blue advanced frame size ML, frame 1.225 g, with derailleur hangers and bottle cage bolts, without those 1.200 g estimate
fork 450 g "almost" uncut and seatpost about 195 g (my own measurements)
Orion nebula advanced frame size ML, frame 1211 g, uncut fork 470 g, seatpost 195 g (my own measurements)
Tour 1195/491
Advanced SL Jayco Alula team color my23 , ML frame 975 g (isp system) , fork uncut 411 g (Tour magazin), isp seat clamp 100 g ? I dont know the weight
RDY
by RDY
Guessing a new complete bike with this included will be released soon and it'll be tested in Tour ... should give them another 3-4 watts.
Maddie
by Maddie
Eterna7m wrote:
Thu Jan 25, 2024 12:01 am
Simple, it's good bye warranty :-) Not that I'm worried too much about that. I do some basic checks though: inspect for any obvious surface damage (paint, hairline cracks), weigh every part of the frameset separately, check seatpost fitment and measure the bottom bracket and headtube bores with an internal micrometer. If that's all ok, then it's knife-time. And before assembly, I tap all the threads and face the caliper mounts on the frame and fork. If the frame fails or has a problem at that point, then I'll live with the consequences :lol: :lol:
The frame is supposed to arrive in two weeks.
Dai
by Dai
Hi all, quick question on cutting the steerer. Obviously with the factory stem, the steerer comes cut about 5mm below the top of the stem to allow for the expander plug and for a little bit of movement for the top cap to do its job.
I'm used to other bikes that require you to have the steerer extend above the stem by 5mm or so. I can't find any advice from Giant on how the steerer should be cut/installed.
Any advice or pointers to Giant docs would be gratefully appreciated.
bedampft
by bedampft
Dai wrote:
Sun Jan 28, 2024 6:56 am
As with every Giant or Liv bike: As it arrives from the factory.
Meaning:
- Steerer cut below the top of the stem, above/at the upper bolt.
- Bikes come with the maximum amount of spacers allowed.
- Max Disc diameter is depending on the adapter already in place. So if it's a 140mm Disc at the rear, but a 160/140 adapter, you can run max. 160mm. Some for the front.
