Elilee XXE Crankset
zappafile123
by zappafile123
toxin wrote:
Thu Dec 21, 2023 1:41 pm
The elilee cranks have 28mm axles so you have to use the provided plastic sleeves. So there's no direct contact with the bearing
I know... I'm still skeptical that a sleeve will stop wear and tear. Carbon surfaces dont like any friction. Would be cool if Elilee did some testing and showed us what the spindle looks like after a simulation of 20,000km of riding. Maybe its not an issue, but if its got a realistic life of say 15,000km then its not worth it. OTH maybe you're right and the sleeves save the spindle from a slow death.
FactorOne|SartoSeta|StorckF.3|Enigma EliteHSS|SworksSL6|ColnagoC60/V3Rs|DeRosa Protos|BianchiXR4/2|BMCSLR01 16|Cdale EvoHM|Focus IzMax|RidleyHe SL/SLX|BH Ulight|BassoDiamante|Scapin DyseysS8|TimeRXRS/ZXRS|TCR SL|RidleyNoah|Look585|CerveloS5/S3
RDY
by RDY
Elilee are teasing a new 24mm spindle design for the new year. Crank arm looks different to the Novanta-X, but it appears it's going to be a super light 24mm option.
Wai8
by Wai8
RDY wrote:Elilee are teasing a new 24mm spindle design for the new year. Crank arm looks different to the Novanta-X, but it appears it's going to be a super light 24mm option.
They already do a 24mm version. Are you saying another different version?
Aryeh
by Aryeh
Looks pretty different Image
aeroisnteverything
by aeroisnteverything
This will be the ultimate crankset for BB86 frames.
nunokas
by nunokas
Aryeh wrote:
Wed Dec 27, 2023 2:48 pm
"Trecento"
So,latin for a "three hundred" gram (arms and spindle).
RDY
by RDY
It's presumably carbon 24mm spindle with revised arms, the latter of which will presumably also be pushed to the novanta. Can't see them getting near 300g with a Ti spindle.
alanyu
by alanyu
The new 24 is still Ti spindle, with a thinner wall but keeping nearly 24 mm OD instead of shrinking to 20. It will be stiffer but less strength (from overkill to more than enough strength)
BigBoyND
by BigBoyND
aeroisnteverything wrote:
Wed Dec 27, 2023 8:48 pm
Only if the price is competitive. SRAM Red Dub is still the best value and 4030 bearings work perfectly fine.
micky
by micky
nunokas wrote:
Wed Dec 27, 2023 9:22 pm
"Trecento"
Actually it's italian, but can't blame them!
RDY
by RDY
alanyu wrote:
Wed Dec 27, 2023 10:51 pm
The existing one is 20mm with reducers?
alanyu
by alanyu
RDY wrote:
Thu Dec 28, 2023 9:43 am
No, 24mm at the bearings but reduced to 20 in the (long) middle
spartan
by spartan
this crankset is targeted at shimano users who are upset how heavy dura-ace/ultegra chainsets weigh.
i hope this Elilee is simple plug/play installation . no silly spacers required.
BigBoyND wrote:
Wed Dec 27, 2023 10:53 pm
Current Rides:
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
BigBoyND
by BigBoyND
spartan wrote:
Thu Dec 28, 2023 4:59 pm
What do you mean by "silly spacers"? There are no spacers involved and I swap BBs anyway because most bikes come with cheap cups. Whether I get 24mm or 30mm makes no difference.
spartan
by spartan
what i mean is that can you just swap out shimano cranks or do i need to buy a new BB
Current Rides:
ex 2019 S-works SL6
