Panaracer Agilest
jlok
by jlok
Got a pair of 28c Agilest TLR at 237g/245g.
Tread is 32-33mm wide while the total width is around 67-68mm. When installed on my Bora Ultra WTO 60 with 19mm int width at 80psi, they measured 27.1 and 27.5 wide. Panaracer says the tires are built around 19mm int width, maybe they will expand a bit after some use?
They are a bit tight and I have used tire lever to finish the last few inches. Didn't bother to apply soapy water; no booster and no valve core removal. The beads just seated with a normal track pump.
Tread width
Tread width
Gonna try them later today.
BigBoyND
by BigBoyND
Is Agilest the replacement for Gillar (which didn't have a TLR option)? The Gillar has been a great tire, imo.
jlok
by jlok
BigBoyND wrote:
Fri Jul 15, 2022 10:33 am
I think the Agilest Light could be considered as the successor?
https://panaracer.com/en/products/road_ ... -light-en/
alanyu
by alanyu
Agilest looks more like the replacement for Race series.
alanyu
by alanyu
Where did you get them? I can't find them around in EU.
jlok
by jlok
You can try Rakuten JP and then ship through their own Rakuten Global Express delivery service. Not easy but possible.
BigBoyND
by BigBoyND
I used Amazon.jp for the Gillar
jlok
by jlok
BigBoyND wrote:
Fri Jul 15, 2022 12:27 pm
Yes, now Amazon has the Agilest as well. I went to Rakuten for pre-order.
BigBoyND
by BigBoyND
Is there any rolling resistance data on this tire? BRR only has the Evo 3 and nothing since then
BigBoyND
by BigBoyND
alanyu wrote:
Fri Jul 15, 2022 11:05 am
Starbike has them in stock now, so they seem to be arriving in EU now
alanyu
by alanyu
BigBoyND wrote:
Fri Jul 29, 2022 7:53 am
Good news! Now I'm waiting a bit more to check if bike24/bc etc. will have them in stock. Starbike doesn't cover VAT to CH
Klaster_1
by Klaster_1
Did anyone try Agilest TLR 28mm or 30mm with 21mm internal width rims, what's the measured width? Looking to replace my porky 268g 28mm Pro One with either of these.
BigBoyND
by BigBoyND
Klaster_1 wrote:
Fri Jul 29, 2022 10:08 am
You can add 1mm to the measurement in the first post for the 28mm version
BigBoyND
by BigBoyND
jlok wrote:
Thu Jul 14, 2022 9:50 am
Have they stretched at all?
jlok
by jlok
BigBoyND wrote:
Fri Jul 29, 2022 12:10 pm
They become 27.8 front / 28.4 rear. I guess the difference might be caused by riding them at different pressure (70/80psi).
