Are these the lightest disc brake hubs? Tactic TR01 (aka Princeton Carbon)
wickedstealthy
by wickedstealthy
naavt wrote:
Thu Feb 09, 2023 12:10 am
wickedstealthy wrote:
Sun Sep 04, 2022 8:19 pm
ryanw wrote:
Tue Jan 04, 2022 11:11 pm
Just ordered a pair of these to try out.
Wheel build will be as follows:
Tactic TR01 hubs - 24/24H - Shimano Freehub - 215g
Enve 5.6 Disc rim front - 54mm - 454.5g
Enve 5.6 Disc rim rear - 63mm - 483.8g
Sapim CX-Ray SP spokes x 48 - 230g (approximate)
Sapim alloy nipples x 48 - 16.8g
Total - 1,400.01g
Would love to get these under 1,400g, but we shall see...
Nice
You can! Just swap those Sapim CX-Ray by Alpina Hyperlite spokes. From head you will shave some 50g on those!
But Im not sure about the compromise there. A lot of builders adviced against using CX Super for that reason so stopped at cx-ray
wickedstealthy
by wickedstealthy
Checked my Garmin. Around 3.5k km done
No visible wear to be seen. Nothing
Got this picture from the wheelbuilder
KarlGLS
by KarlGLS
wickedstealthy wrote:Checked my Garmin. Around 3.5k km done
How many Kays on then now ?
simply blabla-ing
wickedstealthy
by wickedstealthy
KarlGLS wrote:
Tue Mar 21, 2023 9:53 pm
Around 4k km now. Just riding fine. They likely need more maintenance but I would expect that you do so if you spend that amount of money :D
I mostly ride nowadays on the indoor trainer on another bike till the weather appeals to me :D
walfisch
by walfisch
I was looking to get a set of wheels with the Tactic hubs, but my friend told me to avoid them at all cost.
"Water ingress into the hubs", "rusting occurs" and "require constant maintenance"
Anyone has encountered such problems?
rollinslow
by rollinslow
walfisch wrote:
Tue Dec 05, 2023 12:49 am
I thought these were primarily made from aluminum so what would rust? Bearings?
I was actually thinking of building a set of Alta's with the Tactic 01 hubs. Would be a sub 1200g wheelset.
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-SRAM Red viewtopic.php?f=10&t=174523
BigBoyND
by BigBoyND
rollinslow wrote:
Sun Jan 07, 2024 3:17 pm
Any reason to go for Tactic-labeled ones instead of Non-Plus? At least here in EU the Non-Plus branded version sem to be significantly cheaper.
1llum4
by 1llum4
As far as I have seen, Non-Plus branded hubs are only available in J-Bend and 6 bolts option while tactic branded hubs are only available in straightpull and centerlock version.
BigBoyND
by BigBoyND
1llum4 wrote:
Mon Jan 08, 2024 1:05 pm
Looks like the listing is gone on R2 but it was there last week.
900€ including VAT, straightpull, CL.
1llum4
by 1llum4
Nevermind I was wrong there is a straightpull centerlock version of Non-Plus hubs on R2.
https://r2-bike.com/NONPLUS-COMPONENTS- ... b-SRAM-XDR
Buexx
by Buexx
Anyone that has those hubs can comment on replacing the freehub body / cassette interface without their toolset? I checked their video and they use their 170Euro toolset to remove the axle first. Can I get off the freehub body without this step, like on any other hub? The picture of wickedstealthy would suggest it is just like with any other hub?
mike
Resident Pro
by mike
if these are anything like the dash cycles hubs, stay away. my rear one locked up after a few rides.
DogmaHiFi
by DogmaHiFi
i havent heard anything bad for these hubs, I am actually waiting for the delivery of my PCW Wake 6560 Evolution with Tactic TR01.
Considering their price i would go for the toolkit for sure
BigBoyND
by BigBoyND
mike wrote:
Tue Jan 16, 2024 4:04 pm
What does this hub have to do, or have in common, with three Tactic/NonPlus?
mike
Resident Pro
by mike
both used tiny bearings and both were the lightest at the time. i recommend going with light yet solid hubs like tune. or go with somewhat heavier but excellent hubs: campagnolo, dura ace, white industries, chris king,dt swiss
