The Shimano 11s to 12s compatibility thread
CyclingGiraffe
by CyclingGiraffe
violino wrote:
Sat Oct 29, 2022 8:37 am
Hi,
since new calipers (br-r7170/8170) are now officially compatible with previous generation STIs (st-r7020/8020 so even regardless of servo wave), do you think it would be worth a shot to try e.g. br-r7170 with even older st-rs685 (this one actually has servo wave) non-series Ultegra level STI?
Well, the official compatibility chart says no, but I suppose you could try it, with the understanding that it may not work.
Ritxis
by Ritxis
Hi,
I have gone from Ultegra Di211 to 12, I don't notice any difference from 8070 to 8170...........with the new calipers, you gain that 10% extra space and bleeding is more efficient......
E46M3
by E46M3
Has anyone actually installed the br8170 calipers on 11s di2?
I managed to accidently find them on sale so pulled the trigger considering price alone and easier bleeding, still not sure about the 10% clearance but I guess we'll see.
milanv
by milanv
E46M3 wrote:
Tue Nov 29, 2022 6:04 am
And did you read this thread? Yes, better clearence mentioned many times, not only here.
E46M3
by E46M3
milanv wrote:
Tue Nov 29, 2022 6:56 am
What's with the hostility? Of course I read the thread, please point me to a post where a user has confirmed the marketting and actually installed them?
milanv
by milanv
Marketing? 8)
milanv wrote:
Tue Sep 27, 2022 9:36 pm
Yes
viewtopic.php?f=3&t=170626
milanv wrote:
Sat Aug 20, 2022 8:01 pm
Brennendw wrote:
Sat Aug 20, 2022 7:40 pm
Can't find anything online or in the forum,
Wondering if you guys have any idea of the Newer 12 speed BR-R9270 calipers will work with the old 11 speed dura ace levers?
Can't see why not..?
Anybody tried this?
Yes, it is working very well, for example in one of my bikes.
Here you have many information about it from other people.
viewtopic.php?t=156208
Compatibility chart from Shimano
https://productinfo.shimano.com/#/com?c ... acid=C-499
milanv wrote:
Sun Sep 04, 2022 5:26 pm
Conradsleight wrote:
Sun Sep 04, 2022 4:41 pm
Sat Aug 27, 2022 4:02 pm
Can anyone advise on what the verdict is on the new brake calliper clearance compared to 9170?
I just got a Factor Ostro built up on a 9170 groupset and already running into rubbing issues. Wondering if it's worth upgrading the callipers for the extra brake clearance?
Can anyone shed some light on this? Are they much of an improvement in terms of clearance?
So again, yes, yes, yes, no marketing, yes.
milanv wrote:
Sun Sep 04, 2022 6:42 am
NordicSal wrote:
Fri Aug 26, 2022 4:20 pm
Can you have 12s shifters and calipers on 11s gears?
Anybody tried this?
And it is not marketing, bigger space for rotors truly exists.
JaeOne3345
by JaeOne3345
It works just fine. I have the 9270 calipers installed with 8070 levers. I have installed 8170 calipers for a few friends with 80xx/91xx levers.
Yes, the clearance is real. Many people are looking at the bleed block width being the same and assuming the clearance claims are BS, but the clearance comes from the piston retraction.
TerryDi2C
by TerryDi2C
Yes, it works just fine ;-).
Personally, I think the extra clearance is great... but it's still very little. Sure, there's 10% extra clearance and that's cool... but 10% of next-to-nothing is still next-to-nothing :).
MichaelB
by MichaelB
TerryDi2C wrote:
Tue Nov 29, 2022 8:01 pm
In Aussie parlance, we call that extra clearance "a bee's dick" :thumbup:
Sock3t
by Sock3t
Where'd you find them on sale?
prenard
by prenard
Maddie wrote:
Fri Oct 08, 2021 10:45 am
I was a bit surprised that Shimano gives official clearance to using old stis with new calipers. But that's good news. I will try the opposite and build new stis together with 9170 calipers. It is very very rare that I have the known tingtingting after descents so I believe I don't really need new calipers and can get away with the old ones. But I do like the better modulation of my grx levers (with servo) and I hope this will transfer to my 9270 levers and 9170 calipers. Might take a while to find out though...
Gesendet von meinem SM-G973U1 mit Tapatalk
Did you try to use ST-9270 shifters with BR-R9170 calipers ? Good result ?
Thanks for your help !
expatscot
by expatscot
MichaelB wrote:
Tue Nov 29, 2022 10:53 pm
UK engineering parlance is "gnat's cock".
Look 695 aerolight eTap 11
Boardman TTE eTap 11
Brompton S2 LX ti custom
Trek 5500 1994 Sram Red 10
Boardman CXR9.8 eTap 11
Open UPPER - DA 9270
Ridley x-fire Sram Red 10
and lots of non- WW others.
Cannoli
by Cannoli
Will the DA-9200 crankset and chainrings work with the 11-speed front and rear derailleur and cassette? I assume it will but am curious if anyone has experience with this. I already run the 12-speed chain on my DA-9100 setup
Canyon Aeroad CFR Di2 | Canyon Ultimate SLX 9.0 Di2 | Trek Domane SL5 Disc (Gravel Bike / Fly-Away Road Bike) | Orbea Tera H-30 Disc (Touring Bike)
harblhat
by harblhat
The chainring spacing is different between 11 to 12 speed. 12 speed chainrings are closer together. Front shifting will work, but not perfectly.
Maddie
by Maddie
prenard wrote:
Sat Jan 07, 2023 6:52 pm
Yes, it works very well.
