2020 Specialized Tarmac SL7
YH0
by YH0
Sub2 wrote:
Thu Mar 21, 2024 1:29 pm
I've just purchased a July 2021 SL7 Pro and am wondering if there is a simple way for me to check if the steerer recall compression ring and extended bung have been fitted ?
Yes, check the colour: red is the "good one", the black was the previous one that was recalled.
Sub2
by Sub2
Thanks YHO, is it easy enough to take the fittings inside the fork tube out to determine the colour ?
thematzie
by thematzie
chorus88 wrote:
Wed Mar 13, 2024 11:39 am
Here's my SL7,
Basic & boring.
Basic jep, biut in my opinion absolutely not boring. I really like it and I like a bit of understatement. Timeless colour. I like glossy frames a lot. :thumbup:
ullmanz
by ullmanz
I think if the steerer is red, then it's the new one
Specialized SL7 - 7.1kg including Garmin mount, bottle cages and pedals
ullmanz
by ullmanz
Sub2 wrote:
Thu Mar 21, 2024 3:10 pm
You just take off the top cap and you see if the steerer is red.
MarkMcM
by MarkMcM
As above, checking the expansion plug is easy, you just have to remove the top cap and check the color of the expansion plug (new one has a red lip and knurled expander, old one is all black):
The new compression ring is trickier, because it is underneath the headset transition cap. But you might be able to look into the gap between the head tube and the transition, and check if you can see the stainless steel ring:
There are a few slots in the aluminum tapered cap (anodized grey), so you may be able to see the stainless steel ring through one of the slots. The view through the slots may be obstructed, as that is where the cables route, but the hydraulic hoses only run through the front slot and one side slot, so you may be able to see the SS ring through the other side gap.
Sub2
by Sub2
Much obliged guys , I really appreciate the detailed information.
I'll get round to checking it over the weekend and take it from there.
I'm not concerned about an imminent failure as the bike has only covered a few hundred miles and I'll probably be waiting on better weather to start using it , but if it's the down level components I'll change them / get them changed out.
Sub2
by Sub2
Here's my SL7,
Basic & boring.
Looking good, I'd not like to try and hang onto your wheel climbing 👍
eucalyptus
by eucalyptus
Take it apart and check? You will see in 2 seconds if you either have the new parts or not.
cfrankscid
by cfrankscid
Just sold my SW Sl7 after almost 4 years of hard riding. Bought a 2024 Factor Ostro VAM v2 frameset as a replacement.
Thought you guys may appreciate a compare / contrast to the SL7 in my review in the gallery:
viewtopic.php?f=10&t=175127
LeMillion
by LeMillion
Took some proper shots of my Sl7 I got custom painted 5 months ago. I had the bike for 2 years and when the SL8 was revealed, I couldn't see myself upgrading. Current weight with the CLXIIs, pedals, cages, and mount is 6.77kg. I'm probably going to buy a 45mm wheel set which should bring it down to ~6.45kg.
scottydonald
by scottydonald
looks awesome!
Beancouter
by Beancouter
LeMillion wrote:Took some proper shots of my Sl7 I got custom painted 5 months ago. I had the bike for 2 years and when the SL8 was revealed, I couldn't see myself upgrading. Current weight with the CLXIIs, pedals, cages, and mount is 6.77kg. I'm probably going to buy a 45mm wheel set which should bring it down to ~6.45kg.
Looks great - would you mind letting me know what spacer you are using for the roval rapide stem (MagCAD?)
Thanks
chorus88
by chorus88
LeMillion wrote:
Sun Mar 24, 2024 7:19 pm
I was thinking of your frameset.
When Technology Becomes Emotion
2023 Tarmac SL7 Expert R8100 (90622-3352)
CAAD8FRED
by CAAD8FRED
What spacer kid are you using on the Rapide?
