What handlebar in the 160-180 gram range?
AGB
by AGB
Noctiluxx wrote:
Wed Jul 31, 2019 10:59 pm
I'm looking to lighten my TCR SL by swapping the current Mavic Cosmic carbon SL UST's (1490 grams) to Bontrager XXX 2 clinchers which come in at 1305 grams. The cockpit, Enve SES Aero 420mm (250 grams), Giant carbon Flux 100mm stem (150 grams), will be replaced with the new Extralite 1.25", 100mm, 80 gram stem, with a 400mm, 160-180 gram range bar. The bike currently sits at 14.03 LBS with Speedplay Ti pedals and Tune bottle cages. Looking to drop the bike in the 13-lbs range with pedals and bottle cages. What bar do you guys recommend?
One of the best looking TCR's I've ever seen......wouldnt change a thing!! :thumbup:
What brakeset are you using as they look mint ?
2017 Giant TCR SL1 | 6.80kg sans
2019 Giant Propel SL0 | 7.00kg sans - WinSpace Hyper 50mm wheel upgrade
Leon
by Leon
wrenegade wrote:
Thu Aug 01, 2019 11:25 pm
I have 40cm Easton E100 bars that weigh in at 175g. Compact bend, 80mm reach, 125mm drop. Love them.
I received mine today. I was a bit disappointed. It weighs 189 grams! Yes, 40cm wide. :cry:
Kick up an old topic. But I wanted to share my experience.
Ride bikes, not tanks!
brumbar
by brumbar
Cadex doing very light handlebars!
Leon
by Leon
I have a preference for Easton for this particular build. I also have a MCFK bar which I'm very satisfied with and which is very lightweight.
nickf
by nickf
Leon wrote:
Thu Jul 06, 2023 12:02 pm
Both of my E100 40c bars came in around 179g. The Easton bar geometry just work for me it's worth the extra weight.
bobones
by bobones
These are light (160g) and cheap (down to £90 from £150). All sizes from 36 to 44 cm in stock.
https://www.wiggle.com/p/prime-primaver ... -handlebar
Leon
by Leon
BTW: had the same experience with Thomson bars. For again another build I ordered a 40cm Thomson carbon bar. Listing says 188gr. Real life is 203gr. So not only Easton is heavier but Thomson also.... And the MCFK bar in 40cm is listed 151gr and came in at 161gr.
Since losing grams is way harder then adding grams it is a bit of pity that it seems that all bars I recently bought come in heavier than listed.
TobinHatesYou
by TobinHatesYou
My 38cm Pro Vibe Superlight weighs 153g (154g claimed.) Not the stiffest bar, but plenty stiff for me.
Mansteinman
by Mansteinman
TobinHatesYou wrote:My 38cm Pro Vibe Superlight weighs 153g (154g claimed.) Not the stiffest bar, but plenty stiff for me.
very stiffness bar
Enviado desde mi 2107113SG mediante Tapatalk
TwiggyForest
by TwiggyForest
jch3n wrote:
Thu Jul 06, 2023 4:49 pm
EXS R150 or R180: https://exs-cycling.com/products/r180-r ... -handlebar
I'm happy with my EXS r180, came in at 182g for the 38cm at the hoods model.
alanyu
by alanyu
Leon wrote:
Fri Jul 07, 2023 7:12 am
MCFK is famous for its disability to use a scale correctly.
Leon
by Leon
Well, I have 2 MCFK seatposts and they came in spot on weight.
I ordered a Cadex bar in 40cm for a new build. Should come in around 150/155grams. So let's wait and see when it arrives.
bobones
by bobones
Folks in the UK can grab the 160g carbon Prime Primavera X-Lite Pro for £45-60 (size dependent) currently at Wiggle (EXTRA10 % off)
https://www.wiggle.com/p/prime-primaver ... bar-31-8mm
Leon
by Leon
I got my Cadex race handlebar today. Spot on weight. 157gr 40cm wide.
