Dura-Ace R9200
OtterSpace
by OtterSpace
Lelandjt wrote:
Fri Mar 29, 2024 2:06 am
What is this part?
It is for routing the Di2 cable at the back of the RD.
Lelandjt
by Lelandjt
Thanks. Never seen that before. Weird thing, my front derailleur didn't include the cable guide so I was looking at this piece to see if it attached to the front derailleur. Ordering one off Amazon.
warickwrx
by warickwrx
What is this part? I think it came out of the front derailleur box, but maybe rear derailleur.
It is used to secure the di2 cable to inside of the rear derailleur mount, I have found that is does not work to well.
LOWIEV
by LOWIEV
Question about Ultegra cassettes. This may have been covered allready, but couldn't find it...
Whats the difference between the ULTEGRA CS-R8101 CASSETTE & ULTEGRA CS-R8100 CASSETTE?
Is it the updated version of the cassette whitout the clicking noise? Or is it something different?
Thanks!
pdlpsher1
by pdlpsher1
No. 8101 is compatible with Di2 and mechanical shifting. 8100 is Di2 only.
Lelandjt
by Lelandjt
pdlpsher1 wrote:
Mon Apr 01, 2024 9:05 am
Weird. I'd love to know the details but googling turned up nothing. Were both released at the same time?
208
by 208
Lelandjt wrote:
Fri Mar 29, 2024 3:11 am
The fd should come with a 90degree plug routing thingy. I still cable tie mine to the frame just to keep everything tight, though.
harblhat
by harblhat
Lelandjt wrote:
Mon Apr 01, 2024 10:59 am
8100 was released first with Di2, 8101 came later once the mechanical 12 groups came along. 8101 has different tooth profiling meant to better accommodate mechanical shifting, whatever that means. 8100 will work with mechanical (I do it) but it's apparently not 100%.
Lelandjt
by Lelandjt
208 wrote:
Mon Apr 01, 2024 12:08 pm
Yeah, this was straight from Shimano via their employee purchase program. That one part was missing. The cable is okay now but I'd rather have it routed a little tighter via the guide. I ordered one from Amazon for $8.
BdaGhisallo
by BdaGhisallo
harblhat wrote:
Mon Apr 01, 2024 12:22 pm
I would have thought that DI2 would impose more demanding shifts on a cassette than mechanical typically would.
Hexsense
by Hexsense
BdaGhisallo wrote:
Mon Apr 01, 2024 2:54 pm
And it is more precise at doing overshift and back off.
Say you only need 1.8mm (make up number) of cage movement to sit in the middle of next cog. The Di2 RD may move 2.1mm initially to help speed up the shifting then back off to the rest location. Cable actuated gears 's overshift action is at the mercy of the rider for the down shift (to an easier gear) and simply not doable for the up shift (to the harder gear).
So, a cassette for mech gear must allow the gear indexing to be less precise and don't rely much on overshift to crisp-ly change gear.
robbosmans
by robbosmans
How do these shift with shimano 12s?
GONE4ARIDE
by GONE4ARIDE
robbosmans wrote:
Mon Apr 08, 2024 4:56 pm
I am also curious to see feedback re: 12 speed.
I am using the Buzz chainrings with Shimano DA Di2 11s and the shifting performance is outstanding.
foobaar
by foobaar
I use them with Ultegra 12 di2 - it works, even with 52/34 on my bike (images for this combo viewtopic.php?f=4&t=161754&p=1823639#p1823639)
robbosmans
by robbosmans
Nice thanks, i know they will never shift as good as shimano’s but if its at least 80% as good i can live with that
(Thats a lovely crux build!)
