S-Works Venge 2019
BigBoyND
by BigBoyND
RSL VR-C in 38cm width
Metaleckz
by Metaleckz
BigBoyND wrote:
Sun Jul 02, 2023 6:48 am
You got pics?
BigBoyND
by BigBoyND
Metaleckz wrote:
Mon Jul 03, 2023 8:32 pm
You got pics?
scapewalker
by scapewalker
Can anyone recommend a cheap but not too heavy 165mm crank for the Venge?
Trying to match crank length to my other bikes and would rather not switch the bottom bracket.
BudhaNL
by BudhaNL
A slightly related question.
I am looking to replace the Ultegra 52/36 crankset on my 2019 Venge Pro with a Sram Red 50/34 BB30.
Would that require adapting the crank itself as well beyond removing the shimano 24mm adapter that is in de Pro frame (if I read correctly in these 237 pages, I'm not particularly technical...)?
Thanks!
robbosmans
by robbosmans
scapewalker wrote:Can anyone recommend a cheap but not too heavy 165mm crank for the Venge?
You can find bb30 sram red cranks 2hand pretty easily for not much money. Very light too.
scapewalker
by scapewalker
robbosmans wrote:
Fri Aug 25, 2023 3:09 pm
Would this crankset https://www.starbike.com/en/sram-red-cr ... peed-bb30/ work with my Dura Ace Di2 Venge? I'm not very savvy :lol:
Jaisen
by Jaisen
robbosmans wrote:
Fri Aug 25, 2023 8:40 pm
Yes
What chainrings would work? It seems this crankset uses the 110/130 BCD standard with 5 bolts, but I think Dura Ace chainrings are on 110/130 asymmmetric 4 bolt BCD? Does anyone make Shimano chainrings with a 5 bolt standard?
robbosmans
by robbosmans
Those stock chainrings will work fine with Shimano, Praxis is also good. I would go for 110bcd
Charlie69
by Charlie69
Has anyone managed to fit a roval rapide cockpit to a venge with a slammed stem? Is anyone making a combined dust cap and transition spacer that might make this possible?
AZR3
by AZR3
Charlie69 wrote:
Fri Sep 08, 2023 11:05 pm
Try these guys, they seem to do a bunch of custom headset covers for a variety of stems/integrated bars
https://instagram.com/thestickybottle?i ... FlYzFmZQ==
Charlie69
by Charlie69
AZR3 wrote:
Fri Sep 08, 2023 11:30 pm
Thanks very much 👍
adriant
by adriant
Does anyone know if the geometry is the same for sl7 and venge?
Is the stack from the sl7 higher? The mandatory spacer is not included on Venge?
adriant
by adriant
Does anyone used that spacer?
https://www.racewaredirect.co/shop/spec ... er-spacer/
And got any pictures?
