S-Works Venge 2019
The sl7 stem is lighter and plug and play?
Inviato dal mio iPhone utilizzando Tapatalk
So is there something p&p and lighter?
I read the whole thread but I don’t remember anything
I had Martyn @ Raceware make me a custom 3D printed transition spacer for my THM stem
Also had him make a custom faceplate insert out of steel for computer mount to support both a 1040 and GoPro so it doesn’t slide down.
- eucalyptus
That is the most beautiful thing I have seen today
Any more pictures???
IMO it would only look good if the stem is slammed
Here we are!!!!!
7.7 w pedals (be pro) garmin mount and bottle cages
28mm tyres with tubes
Yeah I tried that but my ocd kicked into overdrive - I wanted a seamless integration that followed the lines of the stemneorc wrote:Another elegant solution for the THM/Schmolke stems is a 3mm carbon adapter plate. Between spacer and stempicture of Jirawat Bank Doungratssamee (Facebook)
Fantastic bike>fantastic ride
Forearms on the handlebar, 40kmh on a flat road @270w: amazing!
Now I need to switch the crankset to a compact one but it seems that a part from thm there’s nothing significantly lighter from Sram red
- wheelsONfire
You can always go for FSA K-force light. I have a 50/36 setup and it shifts better than Sram. Plus the DS crank arm have more clearance to the FD cagerobertonavaz wrote: ↑Wed Sep 21, 2022 9:38 am
560g is the weight of mine with chainrings.
Bikes:
Open *UP* (2016.04.14)
Then that's heavier than Sram Red Exogram BB30 crankset.
Sram Red Exogram BB30 with stock chainrings are 520g. viewtopic.php?f=3&t=141373#p1261958
It become sub 500g with Praxis chainring or something lighter.
Sram 50t weight 125g, Praxis Buzz 50t weight 104g.
- wheelsONfire
Yupp, don't have Exo. But there are other benefits like clearance to FD cage and better shifting using 50/36.Hexsense wrote: ↑Wed Sep 21, 2022 10:57 pmThen that's heavier than Sram Red Exogram BB30 crankset.
As a side note, you can also shift full cassette with both chainrings without any rub. 11-28 and 11-26.
Bikes:
