Hi Everyone,
I'd like to run the smaller (and supposedly cooler) Shimano DA rotors (140mm) with SRAM eTAP HRD Flatmount calipers. Will this work?
I'm trying to keep the total bike weight down and I personally like the look of the smaller calipers, but live in a hilly/mountainous place ( Salt Lake City). I'm hoping that the smaller Shimano rotors with cooling fins, combined with the SRAM hydraulic system (that uses DOT fluid) will keep things cool on the long descents around here. Not that I brake that much on descents, but I want to make sure I stay with some margin of safety.
Thanks in advance!
Do Shimano DA Rotors work SRAM eTAP HRD Calipers?
Yes the RT900 works with eTap HRD pads, with added noise due to the vent cutout design. I'm using this combo at the front.
Sent from my SM-N9500 using Tapatalk
Don't! would be my advise. I thought the Shimano rotors were great when I first had them and have been pretty quiet, but the warp all the time under braking and need constant retruing. I've now gone Sram Centreline X and they are so much better.
^ This.
Shimano rotors tend to gobble like a turkey with SRAM calipers/pads. I also experienced this with TRP Spyre SLCs, which use old Shimano style pads.
Centerline X have been flawless.
