Bleed screws in Shimano hydraulic levers
still pondering this as caps not arrived yet. Just ordered one of these sets, figured might be better than the torx as they have a 2mm option. This is getting expensive https://www.lasertools.co.uk/product/6844
Had this issue 3 weeks ago, my LBS was building my new Propel and one of the bleed screws was stuck so he could fill/bleed the system. He (and i) wouldn't suck it up and my LBS contacted Shimano. They acknowledged it as warranty case and 3 days later i've had a new R9170 shifter. Thanks for that.
This 2mm allen key just askes for overtightening.
these seem absolutely jammed on from the Specialized factory build. No sign of budging before they rounded. Both levers. Not sure a warranty claim would be a goer as a non-mechanic (me) has messed with them. That said the number of places selling spares is quite telling
Just thought I’d share this in case someone else has the same experience as me. When I was bleeding my brakes a few weeks ago, I thought that I had stripped the head off the 2mm hex. It turns out that I had not fully inserted the hex wrench into the bleed screw and I was simply turning the top part of the screw body.
By pushing the hex wrench deeper into the bleed screw body, I was able to unthread the screw.
I had one screw where pushing the allen key in all the way loosened it.. the other side this made no difference.. the shop tried the torx key method but ending up hving to drill it out... I ordered 4 from SJS.. took about a month to get to Canada but I have spares... bad design... :/
I am at my wits end with this. My hex extractors and spare caps arrived today. Not a hope. Just chewed it up even more. So I then hammered a torx T10 in , Good quality set, unused. Same result . These things have been put on so tight either at Shimano or Specialized that they will not move. Dunno where to go next with this.
Dang... I stripped the screw and will need to use the T10 trick....
I couldn’t get the torx to work
So cut a notch - across the head of the screw
And use use a wide flat screwdriver
Works okay...so far
Works okay...so far
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
Sold
Sold -
Currently with lbs , had to take it in for the Roubaix future shock recall. They have got them out but are now struggling to get the front brake to firm up. Ho fecking hum. Should have stuck with my original plan and bought a Bianchi infinito instead of the Roubaix
Yeah.. those things are garbage.. they even come from the factory so tight you can barely get them out... Ive already stripped one having to bleed the system and needed to use the Torx to get it out.. friend at shop needed to have his drilled out... I ordered 3 to have em around.. evidently they are a one shot deal...
