Zipp 202 Firecrest clincher flex
thencameyou
by thencameyou
Any thoughts on this problem team?
My dad's bike has a chain stay mounted DA9010 direct mount brake (Avanti Corsa DR) and he is running 2014 Zipp 202 clinchers as everyday wheels. He is a decently powerful rider and a bit of a gear masher (avg cadence 75-80). Pads are hitting rim most of the time - but especially when out of saddle? Hasn't had the same problem with these wheels on other bikes - will relacing rear wheel to a different hub help? Or any other thoughts?
pdlpsher1
by pdlpsher1
Could the flex be coming from the chainstays? If the chainstays are flexing at the end it would cause the wheel to tilt back and forth. If the same wheel is fine on another bike then changing the hub won't solve the problem.
tinozee
by tinozee
It's a good advice to try in another bike first. Then check the way it wiggles by hand, you can tell if it's preload at the hub by hand. Could be several reasons. Any wheel can get soft with enough pounding on it. My sets of zipp firecrests have been relatively tough though. Only time I had rub it was preload.
Benno
by Benno
Those 202's are tanks. I would suspect it would come from improperly adjusted hubs or some other area, not from any kind of wheel flex.
GT56
by GT56
why change something to the wheels when the obvious problem is the frame > 'Hasn't had the same problem with these wheels on other bikes'
chris47
by chris47
I too had issues with brake/wheel rub on my avanti corsa dr when i was running fulcrum racing zero´s. Since then i have swapped the wheels for some giant pslr 0 carbon wheels and i dont have any issues with it anymore. I suspect that the wheels were the culprit.
NGtim
by NGtim
202's are suppose to be pretty stiff i.e. no flex. Possibly the dishing is out on the rear wheel?
addict
by addict
And rider weight?
I doubt 202s are stiff considering how less stiffer 303 or 404 are in comparison to other similar wheelsets.
