eajohnson wrote:ferrarista wrote:eajohnson wrote:
The only way to remove the pivot bolt that I know is to drill it in the center. The assembly is two part with O-rings like you can see in the file attached. To install you need a special tool that is available only for Campy SC. Some Pro shops also have the tool. You could modify or have something made by a machine shop if you want to do the same thing.
Thanks, the diagram helps and there are some pics online of the repair kit (which appears to only be available to service centers) that also clarify how the parts go together. It's tempting to take one of the derailleurs as a sacrificial learning tool to try to figure out a DIY approach, particularly if the SC won't take my money to look at my derailleurs (I bought them in the USA instead of Canada). Also I wouldn't have had warranty coverage on them anyway because Campagnolo warranty is only valid if you make the claim to Campagnolo in writing within 8 days of discovering whatever the issue is.. that's a pretty tight timeframe LOL I don't think I've ever jumped to making written warranty claim that fast after noticing a problem with anything and probably never will.
I don't see why the SC won't repair your derailleur. It should not be a problem. Where did you hear you have to contact within 8 days of the problem? That's nonsense lol. Warranty is valid weather you discover it at the beginning or end of warranty coverage. You just have to contact the shop or SC directly like you did. When its a warranty they ask you a copy of invoice. I think since you bought your derailleurs in USA it could be passed on warranty in Canada. Campagnolo North America and Marinoni help each other when needed. I know a guy who bought a part in USA and since Campy USA didn't have the parts in stock, Marinoni did the warranty claim. So its possible they can pass the repair under warranty. Will see what they tell you.
