trek madone 9.9 vs pinarello dogma 65.1
trek madone 9.9 dogma 65.1
pinarello
27
32%
trek
57
68%
Total votes: 84
mikemon
by mikemon
has anyone rode the new madone 9.9 how does it stack up against a dogma 65.1 ?? the price tag on the trek is outrageous
CPongpanich
by CPongpanich
The new Madone is arguably one of the best bikes you can buy at this moment.
audiojan
by audiojan
As much as I love my Pinarello F8, in this case, I voted for the Madone. It's both lighter and probably quite significantly more aero.
Are you sure the Madone is lighter than an F8? I don't know I am just asking.
I am not sure if it is significantly more aero either.
audiojan
by audiojan
kgt wrote:Are you sure the Madone is lighter than an F8? I don't know I am just asking.
The claimed weight for the 65.1 is 970gr, but they are usually quite a bit over 1000gr... The claimed weight for the Madone 9.9 is 950gr, but the two I've weighed has both been under that (940 and 925gr). Ok, so not as much of a difference as I remembered it to be. Think I confused the weight of the 65.1 with the 60.1 (which is about 100gr heavier).
In terms of aerodynamics, no question that the 9.9 delivers. The 65.1 was never a very aerodynamic frame... so the difference should be quite significant.
My mistake. I had Pinarello F8 in mind.
desmonello
by desmonello
@ audiojan:for madone 9 you say 940 grams for frameset or only frame without fork ?
if the weight is only for frame, do you know the weight of fork ?
thanks
Desmonello
jimaizumi
by jimaizumi
Have never bought either but as a person who had a Dogma FPX and has always favored Pinarello's, I'm actually leaning towards the Madone. The Madone frameset may be lighter but if you consider that the everything (minus the wheels) is proprietary, the the F8 would be lighter overall? From what I have heard, the M9 brakes are fairly heavy in itself.
THE PAST: 2005 C'dale R700, 2006 Spesh S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato, Cinelli Gazetta
THE FUTURE: :mrgreen: :mrgreen:
garlet
by garlet
trek madone 9.9 win! because of cableing
CanadianBiker
by CanadianBiker
I'll put my vote on the Madone as I just pulled the trigger on one today.
pdlpsher1
by pdlpsher1
desmonello wrote:@ audiojan:for madone 9 you say 940 grams for frameset or only frame without fork ?
thanks
Desmonello
It's kinda hard to compare the weights between the two as the Madone has integrated brakes. One has to include the weight of the brakes to be apples to apples.
Geoff
by Geoff
Check-out the geometry, too. You can get the Madone in the 'H1' size, which might make all the difference to you.
ergott
by ergott
I've tried the brakes on the Madone and wasn't sold. There's a lot of friction in the cable system so they require more effort to grab and you lose modulation feel as a result. I have also spoken to someone that races on one. Didn't like but deals with it. I'd have to see a better sample of one with if that's not indeed the case.
coloclimber
by coloclimber
ergott wrote:I've tried the brakes on the Madone and wasn't sold. There's a lot of friction in the cable system so they require more effort to grab and you lose modulation feel as a result. I have also spoken to someone that races on one. Didn't like but deals with it. I'd have to see a better sample of one with if that's not indeed the case.
Highly dependent on cables and pads.
-Deacon Doctor Colorado Slim
Calnago
In Memoriam
by Calnago
Highly dependent on cables and pads, to an extent for sure, but even more important... routing.
