droitaubut wrote:3Pio wrote:droitaubut wrote:miklm wrote:
Good catch. I looked at the wrong column in my Excel spreadsheet. I had "Spec" (i.e., claimed) and "Actual" and posted the wrong one.
Spec 128g
Actual 131g
My R3 Bars were Spec 245g, Actual 259g so a bit heavier even. I have the "Chameleon"; the R1 are supposed to be around 40g lighter.
https://roadcyclinguk.com/reviews/fizik ... LUCZWc2.97, please see this review, here they actually mention the R3 handlebars to be over 330 grams.. Quite crazy! Do you think this can even be remotely true?
Fizik R3 Handlebars in Bull shape, 42 cm size c-c (in the hoods, i think it's 44 in the drops), actual weight is 259 gm
My friend have it, so before installation i measured it.
Thank you, Im having the R3 chameleon now, but didn't install or measure it myself, it's also the 42 cm c-c though. However, can't imagine a different shape would be very much apart in weight from the bull you mention. I feel I am slightly overstretched. Currently combining a 130mm fizik R1 stem with the R3 chameleon 42 c-c. Will have to consider if a bull handle bar (5 mm less reach) will do the job or I will have to adjust the stem to 120 mm (10 mm less reach). Any thoughts on this situation?
Always easier to replace the stem than the handlebar.I would say try it first with 120 mm stem, ride some time (not just one ride) and u'll realize is it comfy or too short.
