gel pads for handlebars
benzebub
by benzebub
I just bought some leather busyman bar tape and noticed it is quite thin.
I only ride without gloves (can't stand the feeling of them) so I'm thinking about putting some gel pads underneath the tape.
The bar is a Fizik cyrano bar and it's pretty thick, so adding a cork wrap first might make the tape/bar too much of a handful.
any tips on good gel sets, or some other solution?
But I could be wrong
Fixie82
by Fixie82
Fizik gel bar pads are used by a few of my riding buddies, one has had the same set for around 3 years. They offer cushion without being too 'squishy', might be worth a look?
Stolichnaya
by Stolichnaya
I suspect that the gel pads will also make the bar too much of a handful for you.
Consider some tape that is also relatively thin - Liz Skin 1.8 tape or a thin model from Fizik. Check those at an LBS to see if the thickness might work in your case.
AJS914
by AJS914
If you have some old handlebar tape you can just cut some piece to use as pads under the new.
BikeAnon
by BikeAnon
AJS914, have you tried that in the past? How well did it go? Did you use anything stick under the strips?
AJS914
by AJS914
I just used the existing sticky side of some old Deda bar tape but the wrapping it over is what really holds it in place. It results in double thickness on just the areas you want rather than a full double wrap.
Calnago
In Memoriam
by Calnago
I use the Fizik Gel tape on normal diameter bars. And wrap really tight. It's perfect for relatively thin tape like you're talking about. I've tried the thick 3mm Performance Tape from Fizik and didn't like it at all... it was too thick.
BRM
by BRM
benzebub wrote:I just bought some leather busyman bar tape and noticed it is quite thin.
sounds like you never used the right ones.
what exactly you can't stand?
AJS914
by AJS914
FWIW, I really like the Giro Zero gloves. They seem to have zero padding.
benzebub
by benzebub
It decouples my hands/feeling from the handlebars too much, I like the direct contact with the bar, it gives me more feedback and a sense of control.
+ I really hate the tan lines short fingered gloves give me.
fh8425
by fh8425
have u considered using thicker bar tape ?
by Nefarious86
Specialized also do Gel segments for bat padding. 2 thickness options.
Using Tapatalk
fromtrektocolnago
by fromtrektocolnago
I would experiment with different gloves. In my opinion the bar tape is not the best place to look.
Colnago C-59 (Dura Ace)
Firefly(Ultegra)
Colnago C-64 disc(ultegra) with Bora 35 wheels
