Campagnolo on a Litespeed T3 i2?
vinokourov
by vinokourov
Hello,
I've a 'Litespeed T3 i2 2015'. I wanna build them with a Campagnolo Chorus groupset.
The frame is provided with an cable guide on the bottom bracket, but there are no cable guides on the headtube for the cable of the front -and rear derailleur.. So the frame is only for an di2-groupset I think... Are there any solutions to put an mechanical group on it ?
Hope you can help me !
RyanH
by RyanH
This probably would look hideous, but:
http://www.ebay.co.uk/itm/Problem-Solve ... 0601210237
bikerjulio
by bikerjulio
I was thinking something similar. Plus OP has the issue of the rear chainstay stop to deal with.
There's sometimes a buggy.
One.
AJS914
by AJS914
Also, assuming the down tube is round which it is probably not on that Litespeed. It seems like you need to have the cable stops welded on or just go with EPS/Di2.
bikerjulio
by bikerjulio
It has a
biaxially ovalized down tube
so it might be round as some point. However I suspect you are right.
One.
cmcdonnell
by cmcdonnell
I bought a T1 last year and set up with Campy SR. Litespeed had 2 versions and I had to specifically ask for a mechanical frame as the default was the DI2 frame.
Bianchi Oltre XR2 + Campagnolo Super Record 11 + Campagnolo Bora 50C
Litespeed T1 + Campagnolo Chorus 11 + Campagnolo Shamal Ultra
