New Wheel Day!!!
dvdslw
by dvdslw
Just wanted to share my excitement with a new set of wheels I finally picked up today. I got a set of the newly designed Easton ec90sl's. They are 38mm deep, 28mm wide, 19mm inside bead width, 16/20 spoke count, "certified' road tubeless with a sealed rim (no need for tape), and weigh 1,400 grams. Only got to get out for a short ride before dark today and they felt great, no flex under power, braking was way better then I remember the Reynolds Assault/Strikes I test rode recently, and the rear hub sounds like a Cris King hub but only half as loud. I'll report back early next week with a proper review after I ride the Horrible Hundred this weekend which should give me a good idea of how these wheels perform. I have them mounted up tubeless with the 700x25 Fusion 3's from my Ultegra's that I've been riding for the last few months just to have a good baseline for feel and the bike is a 60cm 2013 Caad10 Black Inc.
velomane
by velomane
I look forward to hearing how the perform at the race.
beatle
by beatle
Fusions are great for a long wear tire, but there are better tubeless tires for racing, IMHO.
Jmdesignz2
by Jmdesignz2
what are the best tubeless tires for racing?
mariovalentim
by mariovalentim
the best clincher race tyre that happens to also be tubeless is the Specialized S-Works Turbo Road if you believe this article http://velonews.competitor.com/where-th ... tires-fast
however they didn't include the new Schwalbe Pro One and the new Vittoria Corsa Speed so there's that...
mimason
by mimason
They look good. Enjoy.
Did you actually weigh them? I'm going to wager they are heavier than spec'd.
Horrible Hundred? Florida boy! Weather forecasted at 79 high and 15 mph winds which is calm compared to some other times I've ridden it. You'll have to give a report back. Do you plan on riding it fast paced?
dvdslw
by dvdslw
beatle wrote:Fusions are great for a long wear tire, but there are better tubeless tires for racing, IMHO.
I agree completely, I rode a set of the regular Schwalbe One's and although they were the same weight as the Fusions, they were noticeably faster. Only down side was wear. I look forward to trying a set of their new Pro Ones but can't find any 25's in stock right now and really wanted to use the same tire I was rolling just days before to get a good feel for the new wheels.
dvdslw
by dvdslw
mimason wrote:They look good. Enjoy.
Thanks, no I didn't weigh them but I'll make a point to do so when I get the new tires. As far as a fast pace goes, we'll just have to see how I feel that day. I've never tackled the course before so its new terrain with a lot more climbing than I'm used to but plan to line up behind my lbs and see if I can hang.
Delorre
by Delorre
They're spec'ed to be 1473 and not 1400!! http://eastoncycling.com/en-us/road/wheels/race/ec90slclincher/ Hopefully for dvdslw, they are within spec, or price/ weight ratio won't be that great :cry:
beatle
by beatle
Jmdesignz2 wrote:what are the best tubeless tires for racing?
IRC Pro light so far
dvdslw
by dvdslw
I bought them with the expectation of them weighing the advertised 1,473 grams but upon receiving them and opening the box I then saw the little spec card saying 1,400 grams attached to the spokes (pictured above in post #1) which was a surprise. I'd guess they fall somewhere between the two weights because I spoke with Easton several times about the Aero55's that are the same wheel only deeper and wondered why the listed weights were all over the place? Their response was that they found a way to make the wheels lighter so the listed weights were higher than actual by about 70 grams which corresponds with what I am seeing. I was too excited to ride the new wheels and didn't have a scale handy so I just mounted them up but will weigh them soon when my new tires come in.
As far as "price/weight ratio" goes, I bought them based more on their certified tubeless capability rather than weight. I did settle for the 38's over the 55's because of the weight difference along with the fact that I seem to prefer the feel of a lighter wheel in comparison to a heavier deep profile rim.
jimborello
by jimborello
Good to see someone still using Easton wheels. I dont know why but since the last change they made and the introduction of the aero 55s they are very rare to see, and suposedly the aero 55s are stellar
acetonehk
by acetonehk
mariovalentim wrote:the best clincher race tyre that happens to also be tubeless is the Specialized S-Works Turbo Road if you believe this article http://velonews.competitor.com/where-th ... tires-fast
I won't say Sworks turbo the best, based on the least resistance from lab test :noidea:
CBJ
by CBJ
S-works Turbo Pro Tubeless maybe
https://drive.google.com/file/d/0B3HUmj ... ZjTDg/view
calleking
by calleking
Nice! How many PSI/Bar do you run these on?
2023 Wilier Rave SLR
2022 Wilier Filante SLR
2021 Cannondale Scalpel Carbon 2
