Favorite inner tube, butyl
prendrefeu
by prendrefeu
Could folks post, along with their preferred tube, whether it has a threaded valve or a smooth one?
Some of us may be interested in alternatives!
gravity
by gravity
I'd prefer the smooth ones, but really, I get whatever my LBS stocks.
joec
by joec
are there any smooth ones these days? I only seem to be able to find them with a dirty great seam! which is where they WILL puncture and patching is then a PITA
whydobearsxplod
by whydobearsxplod
Do lyzene pumps that thread on work with these smooth valves?
1415chris
by 1415chris
Lezyne's pump heads thread on the core valve, so whether the valve is smooth or threaded it doesn't matter.
prendrefeu
by prendrefeu
joec wrote:are there any smooth ones these days? I only seem to be able to find them with a dirty great seam! which is where they WILL puncture and patching is then a PITA
Michelin's tubes have the smooth valve variety.
kode54
by kode54
Continental Race 700. had too many pinch flats with the Light or Supersonics...maybe because i suck at mounting tires. since i've been using the tire talc, i haven't had any issues since.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
reknop
by reknop
L84AD8 wrote:Continental Race 700 Light, mine came in at 75g.
Paired with GP4000s, after 2300km still puncture free(luckily?) and surprisingly, improved ride feel noticeably!
I was less lucky with the Continental Supersonic inner tires, so I'm using the normal Continental race tubes at 105 gr. each. The Continental Supersonic inner tires only weigh 50 gr. so half of the normal ones ...
https://www.cycling-review.net
Poulidor
by Poulidor
kode54 wrote:Continental Race 700. had too many pinch flats with the Light or Supersonics...maybe because i suck at mounting tires. since i've been using the tire talc, i haven't had any issues since.
Please excuse me if my suggestion is too basic but it took me some time to figure it out. Of course, I'm stupid.
Anyhow, when you're mounting a tire make sure that you keep the side that is already mounted and the part you're mounting in the middle of the rim. As the inside of the rim is concave you'll get that extra yield that will allow you to mount the rest of the tire more easily. Tires that I could hardly mount with levers, now I can mount with my fingers. I hope this helps.
DeLuz
by DeLuz
RimClencher wrote:Panaracer R'Air
18-23C with 42 mm valve is 66 g
23-28C with 42 mm valve is 77 g
This ^^^
Light, durable, seamless, reasonable cost order from Ribble
Gearjunkie
by Gearjunkie
My favourite compromise is Specialized Turbo 48mm valve.
Pluses are that they are relatively light (70g from memory), hold air well (much better at this than Supersonics), easy to install and come pre talced.
Downsides are availability (only from Specialized retailers and usually not online) and cost.
Cheers
GJ
Rush
by Rush
I run 28 mm tyres these days, so I use the Michelin A2 tube (smooth presta) which has a 40 mm long valve. It is sized for 25-32mm tyres.
MattD
by MattD
Schwalbe Extra Light, or Michelin Aircomp Ultra Light
Multebear
by Multebear
The cheapest ones. I don't care about weight, threads or other stuff. As long as they are cheap.
Butyl tubes for training and latex tubes for racing.
Marin
by Marin
Why is price so important to you, how many do you buy per week?
