Looking for the smallest hand pump possible.
weeracerweenie
by weeracerweenie
Hi all,
I'm looking for who has the smallest hand pump. I need something that's;
- 19mm or less in diameter.
- Prefer Flexy hose
- Somewhat short or telescopic
Anyone have a particularly small one and some calipers to measure them?
I guess there's worse hobbies than making a bike light? Right?
mattr
by mattr
Looks like you need an ipump...... Or not.
viewtopic.php?f=3&t=121998&hilit=Ipump
HTML
by HTML
my Aliexpress pump is 12cm long,22mm wide and weighs 45 grams and fits into a jersey pocket. It does have a slight flaw. You need to use small Schrader-to-Presta adapter with it as when i didn't one time the built in head piece adapter that slides out to switch between presta or schrader came apart and detached while pumping. The way the headpiece is designed, if you use a seperate adapter. There is less chance of it detaching and it feels alot more solid to use. No problems after that.
This
http://www.aliexpress.com/item/Mini-Por ... 5,201409_2
Martin.dk
by Martin.dk
mattr wrote:Looks like you need an ipump...... Or not.
:beerchug: Thanks I had forgotten all about that super funny thread!!
there's so much fun stuff going on there.
/Martin
Samuel Sanchez Gonzalez wrote:Ohh okay! I just knew "plug" was something to put inside a hole... yikes
mariovalentim
by mariovalentim
Had my Lezyne for quite some time and I'm very pleased. It's got 17cm, goes up to 120 and has a flexible hose which won't break your valve while pumping. There's even a WW version of it, the Lezyne Carbondrive Lite with 80gr
uraqt
by uraqt
smallest is one from these guys
http://www.airbone.com.tw/
however, not really usable ...
I use
http://www.topeak.com/products/Pumps/MicroRocketcb
Takes a lot of pumps to get you home
I think the Blackburn pumps might be the best if you include cost ....
http://www.blackburndesign.com/pumps/ai ... etB5ULQe5w
I would have went with the airstik-sl but when I bought the topeak Blackburn was behind a year size wise .....
c
Rick
by Rick
I had two Blackburn Airstick SLs that worked fine when new, but stopped working and fell apart after about a year. Of course I discovered they had degraded at the worst possible time, when I needed to use them.
weeracerweenie
by weeracerweenie
IPump, haha nope. At the shop I work at we stock Lezyne and ideally I'd buy one of them.
@wrcompositi that is a nice pump, any physical dimensions?
wrcompositi
by wrcompositi
weeracerweenie wrote:@wrcompositi that is a nice pump, any physical dimensions?
139x18mm
FYI:http://www.bike24.com/p210632.html(under fact sheet)
Timmy269
by Timmy269
I have the Lezyne. I'm very happy about it
http://www.lezyne.com/product-hpumps-hp ... fLcxJ1CTcs
eric
by eric
The Topeak Micro Rocket is pretty much useless as a pump. You can get air into the tire but it takes about 2000 pumps to get it to a rideable pressure. Also, no hose, so you lose air whenever you tilt the pump slightly.
The Lezyne Road Drive (medium) is not that much heavier but it works so much better. It's worth the weight.
aerodynamiq
by aerodynamiq
I'm in favor of the Lezyne Road Drive, too. Bulky, but does the job.
velonode.cc
kode54
by kode54
Rick wrote:I had two Blackburn Airstick SLs that worked fine when new, but stopped working and fell apart after about a year. Of course I discovered they had degraded at the worst possible time, when I needed to use them.
i had that issue as well. when i first got it...it worked great. had it on the bike and never checked it until i had to use it while on the road. it fell apart at that time. luckily, i have CO2 as well.
i use the CNC Pro mini pump. 19cm in length...has a built in hose you attach to the other side. hasn't fallen apart...since its made quite well. heavier is the only downside.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
mattr
by mattr
kode54 wrote:had it on the bike and never checked it until i had to use it while on the road. it fell apart at that time.
I had a stay mounted full size pump on one of my (very) old bikes, the point at which it failed was when it rusted through and jammed the plunger and shaft into the wheel.
kode54 wrote:luckily, i have CO2 as well.
Spoke key and a rock saved my ride....... :oops:
