Different rim widths between front and rear wheels
I recently picked up a Dura-ace WH-7801 front wheel for a rather small amount of money, and i am in the process of putting together a build for a corresponding rear wheel. Since it is proving very difficult to find a matching Dura-ace rim, I have been considering the H Plus Son Archetype - 23mm Wide Clincher Rim as an alternative.
My question is: Using 25c tires on the front and rear, what would be the advantages/disadvantages to running a ~20mm wide rim up front with a 23mm wide rim in the rear?
Perhaps someone out there has had experience with this....
I've done something similar when situation warranted. I could not tell the difference in handling.
Motorcycles all have wider rear rims (and tires) than front. It works there.
The rear tire will be a bit wider, which is fine.
- wheelsONfire
Enve SES is the opposite...
Bikes:
Open *UP* (2016.04.14)
Is this any different than running mismatched tires, different width tires, or slightly different pressures between front and rear?
I think that's the maximum rim width but not the width at the bead hooks.
saverin wrote:My question is: Using 25c tires on the front and rear, what would be the advantages/disadvantages to running a ~20mm wide rim up front with a 23mm wide rim in the rear?
I always run 23 on the front and 25 rear (same rim widths though), it's a little more comfortable on the long rides with no performance loss. I only run 25's on the font on my old hack bike where I'm nor really worried about max speed.
Would never run 20mm on a road bike again.
