Campag & SRAM mix?
Hello, I'm looking to pop a SRAM Force 22 chainset on my winter bike but I'm running Campag at the moment. Has anybody done this before and how was the front shifting for you using a Campag chain over SRAM rings?
I'm running a Record 11s chain on my TT bike on an FSA solid 10s TT ring and I have no issues at all... can't speak specifically for SRAM though...
Not a problem at all. I'm using Quarq power meters on two of my bikes and my wife has Quarq on 3 of hers. All with Campy Record and SR, both EPS and mechanical. Using KMC X11SL chains with all though.
- jekyll man
Why?
Is your chainset worn out, and it looks a reasonably priced replacement?
From what i've seen of sram bottom brackets, they only last 2 minutes, which isn't great for a UK winter.
Powertorque isnt particualrly winter friendly either, which is why im on the latest 105 4 arm chainset for the winter bike (cheap online) with a hope stainless BB....
Shifting wise, you'll be fine on whatever path you choose.
Official cafe stop tester
Thanks all for your input.
@jekyll man: I'm running a 2011 UT Campag Record c/set at the mo and it's starting to look a little tired and I swear there's a hairline crack in one of the spider arms. Probably best to replace it to be fair - it's still on the original rings!
The Force 22 c/set caught my eye and isn't too badly priced - as you quite rightly pointed out.
