Di2 cable lengths
jano
by jano
Are the cable lengths give for the Di2 cables measured with or without the connectors?
Thanks for help.
goodboyr
by goodboyr
I just measured a 300 I had. End to end against a steel ruler, 302 mm.
jano
by jano
Thanks GoodBoyr!
Excellent info. Means the connectors are included in the cable length.
Jesper64
by Jesper64
If you're looking to save weight there's not a lot of difference for 50mm of wire so always pays to have it slightly long in case anything unforeseen comes up. 50mm of wire roughly works about between 0.5-1g.
jano
by jano
Thanks for the detailed info Jesper!
Not that much about the weight as about not wanting to have a bunch of cables coiled up within the frame.
You are absolutely right that better have them a bit longer then a bit too short!
kode54
by kode54
you do need some extra length if you're putting the seat post battery in. otherwise, very difficult to snap the cable end in.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
jano
by jano
Indeed, planning to go with a 600 mm long one for the battery. Seat tube is 510mm, should leave me enough space to plug it with no dramas.
